I composed a piece in Notion 6 and transferred both audio and midi to Studio One (latest version). When I add a VST to a midi track and select a sound in that VST, it reverts back to the default sound that VST opened with. For example, I place AAS on a midi track and when it opens I select a specific sound (Jade), but when I go to play back it reverts to the sound it opened with (Fat 48). I've tried selecting the sound and saving, but it still switches.
I'm sure this is something simple that I'm missing. Any help?
Dell Inspiron 3880, Intel(R) Core(TM) i7-10700 CPU @ 2.90GHz, 16GB Dual Channel DDR3 1600MHz, 256 gb Solid State HD, 1TB 7200 rpm HD, Windows 10 Home (64Bit), Studio One Professional 5.4.0, Notion 6, Presonus Eris E8 Studio Monitors, Presonus Temblor T10 Studio Subwoofer, Presonus Monitor Station V2, Nectar Impact LX 88+, Roland TD-12 V-Drums, Roland FP-30x
Most likely there is a Program Change message at the beginning of your midi part. Which AAS instrument are you using? The response to midi Program Change can be disabled in AAS instruments, you can disable that feature and see if your AAS instrument will switch the patch or not on playback.
Nailed it in one. Removed the program change and problem solved. Thanks Patrick!
Users browsing this forum: AAV and 74 guests
