Hello!
I have created a MIDI Controller in Studio One and assigned commands. The next time I start Studio One, all the assignments are gone... The controllers (20 of them) are still created in the user interface, but the command assignments are completely deleted. It seems that I am not the only one who has this problem. https://answers.presonus.com/54716/midi ... sWh6ZaR_i8 But there is no solution so far. In my opinion it is a bug. Or did I miss something? Any work around? Please help! It is absolutely annoying. |
Did you try using it?
I renamed a control and set it to cc74, after restarting the program I see the name is still there but it doesn't show the assignment, just what I named it. That's as it should be. You're going to name all your controls with default names? How you know what to use? Try making a few controls and name them and set them to their cc's. Try and get stuff that you can hear if it's working or not. Close and reopen. What happens to the map you setup when you click the learn button again? Does it show your assignments?
Tacman7 wroteDid you try using it? I am thrilled. The solution to the problem was naming the controllers. After I gave each controller its own name, the information is permanently stored. Great THANKS so much! Sometimes it's the little things that help. @ PreSonus programmers: You should add this to your bug fix list. You can't come up with an idea like this on your own.... |
Users browsing this forum: No registered users and 88 guests
