I'm noticing when working in the editor with midi it create's extra notes when moving the midi notes, also while trying to create a bass line it won't do it, I thought it was the app so I switched out instruments and it did the same thing the midi notes are there but it doesn't playback the sound from the instrument
taylorscott2 wroteWas really hoping for a video track on 5.5. Oh well, maybe v6 I honestly don't get it - with Sphere surely the idea is you can add features as you go, as a new subscriber now is better than a new subscriber in a year or mores time. To have half implemented video in a way that seems like the most technical part is already achieved (with video support) but to not add the smallest feature which makes it usable or realistic someone in media would use Studio One for it.... All I can guess is there's some personality in personus who <really> does not like or understand media composition... Because I'm sure the marketing department is like 'wow, this would be the single easiest win for greater market share'... |
enot wroteI'm noticing when working in the editor with midi it create's extra notes when moving the midi notes, also while trying to create a bass line it won't do it, I thought it was the app so I switched out instruments and it did the same thing the midi notes are there but it doesn't playback the sound from the instrument Just to rule out one possible cause I've encountered: In the past when I have both my V-Drums and a MIDI keyboard active as inputs in S1 and then set the input to omni or "all inputs", I have noticed that it will record two notes at once for a single entry. Your situation may be different, but this is something I had to pay attention to because I usually only ever had one MIDI device plugged in for a session, which allowed the "all inputs" generic setting to work fine except on those days when I was recording V-Drum tracks. That's when I noticed the doubling of notes.
I can't see it myself.
Ok back of the class.
moonpie wrotetaylorscott2 wroteWas really hoping for a video track on 5.5. Oh well, maybe v6 The technical part of video is NOT already achieved because it does not sync correctly with audio. |
Check out Divinci resolve. It's free, better than Adobe Premiere and has great audio support. I regularly use this and studio one together. Studio One will always primarily be a DAW, and Resolve will always be a video editing suite. There is some crossover. Use the right tool for job.
Here's a 5.5 Projects only deviation I just noticed, and inherently a minor bug that needs correction. I proofed it out again this morning,so you guys can verify for me if the opprtunity is there. Thanks ahead.
In song mode, I added the Pro EQ, and created from default some frequency adjustments. I stored my Preset "songnane". This stores the file at: Studio One/Presets/Presonus/Pro EQ/songname.preset. That's the default location. All good, business as usual. I liked that Preset and wanted to use its curve in my Project, so I went to the Project page, and to the same song (doesn't matter, really as the preset can be called up in any song), loaded Pro EQ, and proceeded to load that Preset (import will also load the Preset). What occurred was the Preset loaded fine, however only the nodes were displayed of the Q, dB, and frequency location. The white line curve remains flat at 0 dB. If I adjust any node, even [control + z] back, the curve will update to that single band only. I have to nudge each of the bands nodes to get back what should have been initially pre drawn upon opening the Preset. This morning I thought, let me try another song and see what will happen when I recall that very same Preset. It worked fine!. So I then opened my projects page, and tried to recall the Pro EQ preset in another song. Same error. Nodes are there but no curve of the respective bands. It stays flat at zero. So depending on verification or visibility here, I may re post in the general forum with this subject more visible. Just sharing in the know. Maybe it's already been noted. I hope someone in Q.C. is capturing all such subtle issues.
rotoboy wrotemartinschweitzer wrotedmuckala wrote"Magnifying glass tool" based zooming is broken on this update Works great here! If someone can make a video ... |
In regards to magnifying glass issue dmuckala has a Mac.
patricemazmanian has windows and it works. The others who are confirming the issue really need to update their signatures with their specs so we can see if there is anything in common.
martinschweitzer wroteWorks great here! If someone can make a video ... This is definitely broken!!! Here you have video. https://youtu.be/VM4nQ4P1A3o it looks like it zooms now all tracks vertically instead of selected tracks. |
pawelhebda wrotemartinschweitzer wroteWorks great here! If someone can make a video ... Please update your signatures with specs, the only person who says it's working is running Windows.
PreAl wroteCheck out Divinci resolve. It's free, better than Adobe Premiere and has great audio support. I regularly use this and studio one together. Studio One will always primarily be a DAW, and Resolve will always be a video editing suite. There is some crossover. Use the right tool for job. I'm running a placeholder graphics card (AMD Radeon 370) in my otherwise nicely-specced Win10 PC due to the insanity of graphics card pricing this decade. I'm wondering: Do you know if Divinci requires a more, less, or equally powerful video card than Premiere? What card you're using and whether you like it. If you're aware of any cards that make sense in today's bizarre market? I'm not looking to edit the next Quenten Tarantino epic, I just want to do some intermediate editing like YouTube videos. I was thinking something like a MSI 1660 Super Gaming GTX or MSI 1660 ti Gaming GTX, something along those lines. |
MisterE wrotePreAl wroteCheck out Divinci resolve. It's free, better than Adobe Premiere and has great audio support. I regularly use this and studio one together. Studio One will always primarily be a DAW, and Resolve will always be a video editing suite. There is some crossover. Use the right tool for job. Just install the standard version, it's all you need and it's free. My specs are below,.graphics card is nothing special. DiVinci graphics card support is much better than Premiere.
pawelhebda wrotemartinschweitzer wroteWorks great here! If someone can make a video ... Nope. Broken on Windows here, exactly as shown in the video. |
PreAl wrotepawelhebda wrotemartinschweitzer wroteWorks great here! If someone can make a video ... I have the problem on Mac but a friend of mine has the same problem on PC with Windows. |
I can confirm this is happening here as well, I am on Windows 10.
Presonus Featured Artist (Italy)
My Latest Feature Requests https://answers.presonus.com/73692/s1-essential-feature-plugin-racks https://answers.presonus.com/72506/zoom-to-selection-improvement-vote-if-you-agree Studio One Pro 6 Win10 - AMD Ryzen 9 5900X - 32gb ram DDR4 Gigabyte RTX 3060 Interface: Focusrite 18i20 3rd gen Prophet XL + KeyStep Pro Atom SQ Revelator |
I am on Windows 10 and MacOS Catalina and have experienced the zoom/magnifying glass issue on both.
I use this constantly and it is very annoying. I hope it gets fixed soon. |
Users browsing this forum: marcpeiron and 39 guests
