patrickviens wroteLokeyfly wroteSo it named the layer "Taylor Take 16+". Because there were 15 layers, and it defaulted to the next highest layer number. It would do that to any layer, producing a new layer number (using the highest take number). This I suspect is normal behavior. You will get Taylor 1 (in all versions). It's a next layer duplicate, the Track Taylor name + Take # highest incremented by 1. If you again duplicate the layer (calling it Martin), it will again always resort to the original Tailor track name, take and highest number. It would have to. It's part of that Taylor set. I'm not saying you can't rename, you just don't get layer increments off of another rename (in that set). Now, if you renamed, and dragged that layer to become a track, yes, it then acts like it's own track and increments correctly. You guys will have to specify what the issue actually is. I just compared duplicate layer with v4.6. The only difference is somewhere along the line after 4.6, a pop-up field to rename the layer was added. Layer duplication will always increment to the latest take. On the name of the take itself, where the actual pass occurs, the name will always show the duplicated take number (does not increment). This makes perfect sense also because a duplicate is a duplicate. You can opt to rename the actual pass name in that Take's field if you so choose. This is why I suggest you make a brief one line description of the occurance, so we can get it on the list. It's probably best to follow up with making the observation transparent. The way Roland did, only now you're not asking. Now you're summing the issue up. Your issue is important to you, so be clear about what it used to do (per version x.x), and what has now changed in 5.5. Currently. and perhaps I'm missing something, but Ive done the comparisons, I see no issue.
re; layers naming convention:
For me, it's a simple matter of seeing a window that asks me to make a duplicate and then name it, after which it not only fails to name it in real time (okay, maybe it happens later) but it also activates that layer. My beef: a) Where's the name in the list? b) I don't want that layer active. I'm using it more as a backup so I can regress after an edit — I am interpreting "duplicate" in this instance to mean "copy", not to rearrange my workflow and replace my current MIDI file.
I have no such findings. Still. the fact that you and patrickviens see an issue that wasn't there before, I've added that to the quick list. Thx.
Studio One 5.5 observed issues:
*Instrument notes - Still occasionally frozen. Instrument notes - some additional dragging/non playback issues. *Pro EQ - preset redraw inconsistent. *Shortcuts - missing i.e. track ht, Zoom Full. etc. *Zoom/magnifying glass issues on both Win/Mac *Update loudness - at times, unable to access update feature. Additionally, no possibility to recalculate LUFS after fadeout using automation. *Undo - Control + Z NG.evidentally. (one report). *Clipping - main output is clipping @ 0 dB (Master & Listen Bus. (2 separate reportings) had to lower fader to -0.1 (may or not be relevant). *Folder Index, varied misalignment *Copy and Paste channel settings" menu entries do nothing when used from within a multi-instrument. *Layers naming convention differs (2 reports). Recent findings: On the Pro EQ redraw issue, if the selected preset is clicked a 2nd time, it then redraws the necessary EQ curve. This is a temporary fix.
I'm adding to the list of observed issues:
Pipeline signal will attenuate and in some cases distort. It seems like it's the send signal because the vu meter on my outboard gear doesn't even register much of a signal when this is happening. I'm not 100% sure about this. Obviously it can be a hardware issue but I've never had this issue before and this mysteriously started happening after 5.5. Initially, I was trying to troubleshoot the hardware side... I thought it was on my 500 series modules in the rack, but different modules would be affected at random and also different I/Os. Later I thought it was the 500 rack itself but this issue affects my non 500 rack units as well. I then chalked it up to the ad/da converters and/or the patch bay. I was in the middle of a session and couldn't really afford to unplug the whole rack and test, so I did the simplest thing - went back to 5.4.1. Everything seems to be working like before. This is day 2 so we'll see. Wondering if anybody is having these issues? |
ericma2 wroteI'm adding to the list of observed issues: Stupid questions I know but I've got to ask it.. Have you stopped other plugins in the chain? Have you tried pipeline in a new project with blank template? Have you tried altering the dropout protection settings? (less of it the better). My suggestions aren't up to much but may help rule things out.
Not a stupid question at all! I haven't tried that yet. But I can say right now it is not 5.5. It just happened right now on 5.4.1. This is gonna be a pain to hunt this down. It's most likely hardware. I'll have to slowly play around with this.
There are no stupid questions. Good ask PreAl.
Just so you're aware ericma2, I added a brief statement earlier that hardware issues were not being placed on the list. If it is in fact a v5.5 issue, it would be spotted in this thread anyway, only for the quick list it's too much to maul over drivers, conversions, etc. You probably should post elsewhere if it isn't a 5.5 discussion. Thx. Good luck! Here's a brief list of noted issues by users in Studio One 5.5 from this thread. Not listed are plugin, startup, playback "pops", rendering conditions, or related audio interface issues.
Just to bring up the layers thing again — since I was duplicating a rough MIDI bass track just now using the duplicate layers feature:
When I'm working in a timeline and want to duplicate an event, I click on it and press "D". It then makes a copy of that event immediately after the selected one. It does NOT replace my original event. When I select my MIDI track event in the timeline and press duplicate layer, it gives me the option to name it (which it does in a sort of confusing way) and then IT REPLACES MY EVENT with that newly named layer. So, intuitively, based on my experience with events in the timeline, I'm not expecting this behavior. I want a duplicate as a backup, not as a new version. Maybe that's the problem. Maybe it should say: "Create NEW duplicate version of current file and toss the working copy somewhere else with a name that you probably won't recognize." Yes, it's a long command for a dropdown menu, so an acronym might be more useful here. [ ] P.S. Naming them Bass 1, Bass 2, Bass 3, doesn't tell me anything either, so naming is important, at least when writing. Unless your DAW comes with finished songs already written for you. In which case, I digress.
Lokeyfly wrotepatrickviens wroteLokeyfly wrote Well, I found that different results are obtained when add/duplicate layers commands are triggered with a right click on the Track, or with a right click on a layer. When adding / duplicating layers with a right click on the main track, the added layer shows at the top of the list and is automatically promoted on top (hence the confusion with how custom name appears), and add/duplicate with a right click on an existing layer does not activate it and also does not re-order layers (and the names!). There is two different behaviors, depending on where we right-click. I have never really noticed that. |
I've this annoying bug about the automation lanes since v5... I tried this on my 2 systems... |
patrickviens wroteWell, I found that different results are obtained when add/duplicate layers commands are triggered with a right click on the Track, or with a right click on a layer. [SNIP] Yeah, I was paying attention to this aspect, too, today. I'm just trying to figure out some kind of a predictable workflow that allows me to save and edit in a way that I can regress to a previous part and still recognize it as that previous part (by trusting its location and name) and not having to worry about losing something important. I never realized how emotionally destabilizing MIDI editing can be.
juvandes wrote I watched the movie. That behavior makes no sense. Definitely something wonky going on.
juvandes wrote I can reproduce that quite easily (just with send automations though, It doesn't happen with other automations for me & only happens with the send automation lane that is below the other). However, I'm on 5.4, so as you said this bug may have been there for a while. Let's report this to the support and hope for the best.
Presonus Featured Artist (Italy)
My Latest Feature Requests https://answers.presonus.com/73692/s1-essential-feature-plugin-racks https://answers.presonus.com/72506/zoom-to-selection-improvement-vote-if-you-agree Studio One Pro 6 Win10 - AMD Ryzen 9 5900X - 32gb ram DDR4 Gigabyte RTX 3060 Interface: Focusrite 18i20 3rd gen Prophet XL + KeyStep Pro Atom SQ Revelator |
kisnou wrotejuvandes wrote It's an unresolved bug since Feb 2020. Workaround is to select the Range on the first Send Automation Lane and adjust the intended Lane. I don't want to undermine or minimize the issue, just present a way to work around this.
stefanrauch1 wrote [SNIP] Ewwww. I've been working with MIDI all morning (aka instrument note events) and I've been stalled twice by the selection bug, which I NEED to be fixed before 2024, or the end of the world, whichever comes first...
seanrowley wrote***EDIT*** Man I thought I was the only one having this issue! It doesn't happen to all my plugins but very few of my plugins come up with the same error |
ciroelrey wroteseanrowley wrote***EDIT*** this is happening to me as well on multiple plug-ins. very frustrating
mac mini 2.6 quad core // RME UCX // modded GAP 73 // Warm Audio WA76// Blue Reaktor, Avantone CV-12Shure SM7B, Shure SM57 & 58 mic's // Korg ms2000b // Korg Padkontrol // Novation sl-mkii // DSI Tetra // Elektron Rytm // Moog Sub 37 // '91 American deluxe strat // Squire Jaguar bass // Martin D-15M // Arturia V-collection // Komplete 9 // UVI Vintage Vault//Lots more vst's and plugs...
Same issue here and had to roll back to 5.4.1 to continue working.
overcoat wroteciroelrey wroteseanrowley wrote***EDIT*** |
Users browsing this forum: Thareh and 10 guests
