The following issue:
When using multiple Komplete Kontrol plugins. The NI keyboard shows always the last one loaded. It is not the one opened in the track. So often the wrong one. Is there a way to force the keyboard to load the current opened quickly? The only workaround I found was to reload (deactivate/activate) the instrument/plugin, so the keyboard changed the loaded inststrument. But that takes a while. best regards |
at the top of the Komplete Kontrol window there are tabs. Clicking on the desired tab will connect it and activate the light guide etc.
On the MK1 models (not sure if it's the case with the MK2), you press the "Instance" button on the keyboard and use the knob to select the instance you want and boom, there it is. Unless I'm misunderstanding what you are asking.
Users browsing this forum: No registered users and 79 guests
