If I set a sample offset in the options for recording do I still have to enter that same value in pipeline?
Or are they two different things? My Pipeline plugin always pings a negative number so I dont trust it. seafood buffet carolina beach north carolina |
I never had to use a offset but I didn't use pipeline, just inputs but should be the same.
A tool to use if you need it: https://www.youtube.com/watch?v=lOI1Thjc1Ts
How do you run EQ's and comps without pipeline? Do you just run it straight out of the channels output then back in?
Tacman7 wroteI never had to use a offset but I didn't use pipeline, just inputs but should be the same. |
Right. Mainly I used sound modules that come in as input to tracks and can be recorded or just monitored and fx added etc.
I used a guitar setup where the track I was plugged into outputs to an fx unit and then came back on a track, so takes two tracks like that. That was an eclipse fx on a S/Pdif loop and I was able to track with that setup.
Users browsing this forum: AAV, BobF, DaddyO, Lokeyfly, Vocalpoint and 81 guests
