Middle C ist C4 in scientific notation and note 60 in MIDI.
Why does it appear as C3 in Studio One when I press middle C on the 88-key keyboard?
Is it possible to configure the DAW to show the correct note?
by patrickviens on Tue Dec 07, 2021 4:45 pm
Back in 1982 when midi was developed Roland chose “C4” to represent Note 60. Yamaha, chose "C3" to represent note 60. Other manufacturers even call note 60 C2 or C5. Although the pitch of note 60 is always the same, there is no official note naming norm to this day. Hardware, Daw and plugin developers have to choose what they think is the best method.
Even the Scientific notation method is not yet a standard.
I am not aware of a Daw that offer the option to offset the note names. Some daws can display midi note numbers on their piano rolls which helps to alleviate the problem.
Windows 10 64-bit
IntelCore i7-4700MQ @2.40GHz, 16GB RAM, NVIDIA GeForce GT755M, MOTU Ultra-Lite MK3 Hybrid, IK Multimedia Axe I/O, Axe I/O One, Soundcraft Notepad 12FX Mixer/interface, MOTU Micro Lite Midi Interface, Studio One Professional 6.6
by IanM5 on Wed Dec 08, 2021 12:13 am
Yep, there is no standard but I agree that there should be.
Heavy-handed moderation can strangle a forum
Or just make it a setting. There are several companies for virtual instruments where you can modify this in their sampler/player. Its just a visual thing, the actual MIDI data doesnt change.
Everybody happy.
Faderport 8 | Focusrite Scarlett 2i2 3rd gen
Studiologic SL88 Grand | Yamaha YDP-163 | Yamaha HS8 & HS8S | Austrian Audio Hi-X65 | Beyerdynamic DT770 PRO
Windows 10 x64 | AMD Ryzen 9 3900x | Asus X570PRO | 64GB G.Skill DDR4 3600MHz | 6TB NVME SSD
by shanabit on Wed Dec 08, 2021 3:19 pm
Hit that octave button on ya controller, VOILA
MIDI peoples can't agree on anything since its inception
StudioOnePro 6.1
UA Apollo Twin
OSX Sonoma 14.2
iMac 2013
by fernandomaia on Wed Dec 22, 2021 4:33 pm
patrickviens wroteEven the Scientific notation method is not yet a standard.
On the contrary, since there is a scientific standard, everyone should be using it, for the same reason that nobody should be using imperial measurement units anymore, and with more intensity since in music it's so easy to change, it's just one digit.
https://en.wikipedia.org/wiki/Scientific_pitch_notation
Nando Florestan (composer) / Bandcamp / Soundcloud
by patrickviens on Wed Dec 22, 2021 7:08 pm
Everyone should be using it is not yet a standard. Per your article the Scientific notation concept is apparently 300 years old, but it has obviously never been universally adopted by anyone. For the time being, when people launch their daw or use their vintage, midi capable hardware, they have to think in terms of midi note numbers and frequency because manufacturers, daw and plugins companies still follow manufacturer X way of naming pitches.
The Midi association is coming up, with Midi 2.0, with a protocol to allow all these systems to interface correctly but what people would like, me included, is to have a way to configure the pitch names in daw X's piano roll.
Cakewalk : note 60 is named C5, Octave span starts a 0
Studio One : note 60 is named C3, Octave span is negative
Renoise : note 60 is named C3, Octave span starts a 0
Bitwig : note 60 is named C3, Octave span starts at 0
Ableton Live : note 60 is named C3, Octave span starts a 0
Hardware X or plugin X : it varies as much
Cubase, surprisingly, has naming format preference setting
You can see how much the Yamaha culture (the middle C= C3 culture) influenced everybody involved with Midi.
Cheers
Windows 10 64-bit
by davidlarson6 on Wed Dec 22, 2021 9:18 pm
There's a natural impulse to buy into "scientific" arbitrary standards more readily into other arbitrary standards. There's no particularly good reason to apply this "scientific" standard to our work, considering that it's actually at odds with MIDI, a tool that we use all the time.
Not that the DAWs have it "right" either. Logically, Middle C should be C5, given that it's note 60 (fifth octave) of the digital standard we use.
Even the "correctness" of the example you gave (the Imperial measurement system) can be argued, as much of the Imperial system is binary (units are divided by 2 into next smaller units) and that makes it much easier to estimate quantities. Try cutting a pizza into 10 equal slices; it's much easier to do binary division of the pie. :D
DKLarson
Windows 10, i9, 64GB, 3X 1TB SSDs; Macbook Pro M1 Pro, 32GB, 1TB SSD
Audient iD14, Atom SQ, Keystep 37, Studiologic SL88, Moog Sub Phatty, Kawai MP11SE, Roli Seaboard.
by guydumais on Wed May 31, 2023 4:55 pm
What really matters is to remember that when we're talking about Middle C, it means the C note that is tuned at 261.6Hz, regardless of the instrument.
Studio One's Tuner shows the Middle C as C4 (261.6Hz):
Middle C shown as C4 in Studio One's Tuner
But the MIDI editor shows it as C3:
Studio One's MIDI editor playing middle C as C3.
Orchestral music convention is using C4 as Middle C:
by Lokeyfly on Thu Jun 01, 2023 5:22 am
guydumais wroteWhat really matters is to remember that when we're talking about Middle C, it means the C note that is tuned at 261.6Hz, regardless of the instrument.
That's because on a tuner, middle C (261.6Hz) is C4. The discussion never was about its actual pitch, but that via MIDI, it is displayed as C3. It's an old thread and not really worth rehashing. Though the question will still come up from time to time.
You're concluding with what the original poster was asking. ;)
To your point, fortunately, a tuner keeps things in perspective. The MIDI protocol while much has been industry wide adopted, hasn't landed on absolute MIDI octave ID that is consistent with scientific means.
New song "Our Time"
https://youtu.be/BqOZ4-0iY1w?si=_uwmgRBv3N4VwJlq
Visit my You Tube Channel
https://youtube.com/@jamesconraadtucker ... PA5dM01GF7
Latest albums on iTunes
All works registered copyright ©️
by michaelherbert4 on Sat Jun 03, 2023 10:40 am
Yeah, with MIDI you actually have to think of it as a kind of transposition. And it is irritating, since something like 60 years ago (well before the MIDI protocol) the International Acoustical Society deemed Middle C as C4, which is the designation in EVERY music school and in EVERY music theory textbook, at least in the USA.
You'd think the MIDI developers would have adhered to that, but they inexplicably ignored it.
Studio One 5 Pro
Acer Aspire desktop
Windows 10 i3 9th Gen 8GB RAM
Eris 3.5 monitors
Casio CTK-6000 arranger keyboard
by SwitchBack on Sat Jun 03, 2023 11:06 am
From the Inspector you can transpose tracks on input, so before input arrives at the instrument plug-ins. This should allow you to shift the input to the required octave, yes?
by Lokeyfly on Sat Jun 03, 2023 2:53 pm
SwitchBack wroteFrom the Inspector you can transpose tracks on input, so before input arrives at the instrument plug-ins. This should allow you to shift the input to the required octave, yes?
Sure. It's really the right workaround. That would move the notes to their respective place, up one octave.
It doesn't impact me, but evidently for some who see B4 note played on their keyboard synth/sampler/controller expect B4 played in the DAW. Thats fair. The Track Inspector adjustment would allow incoming notes to shift. Or at least it should like in Cubase. I'd have to verify the shift is placed on the incoming notes. If not, then it's a fix, afterwards. Cubase shines in this sort of MIDI note and filtering adjustment.
New song "Our Time"
by PreAl on Sun Jun 04, 2023 5:52 pm
G needs to be removed from all notes because it doesn't comply with hexadecimal numbers
There I've had my say.
Studio One Pro 6.x, Windows 11 Pro 64 bit, also running it on Mac OS Catalina via dual boot (experimental).
Presonus Quantum 2626, Presonus Studio 26c, Focusrite Saffire Pro 40, Faderport Classic (1.45), Atom SQ, Atom Pad, Maschine Studio, Octapad SPD-30, Roland A300, a number of hardware synths.
Users browsing this forum: hannur, johndoe313 and 69 guests
