Here's what I'm using
Mac Mini - Mac Os Big Sur 11.6 TD-17 Studio One 5 Here's what I was able to do so far.... Purchased, downloaded and installed SSD5.5 (Steve Slate Drums) opened up Studio One 5 and loaded the plugin and was able to click on the drums in the windows and hear sounds I also connected my TD-17 to my computer as a new instrument track when I hit the drums, the audiometer on the track moves as if it's reading the midi signal, however, I'm not hearing any sounds when I hit the drums. ...and this is where I'm stuck, any ideas? Thanks again for all your help with this. |
Welcome to the Forum!
So you're not interested in recording the sound that the TD-17 makes, Just using the TD-17 to trigger the SSDrums. So you probably used the USB port to send midi to the computer? You would create an external device: a new keyboard. You send midi to an instrument but only receive midi from a keyboard. https://s1manual.presonus.com/#Setup_To ... 257C_____4 When you create it you set the receive box to the midi port where your drums are. Then you drag an instance of SSD to the arrange window which will create a new track with SSD on it. The input for that track you set to the device you created and then click the monitor button for live input to be connected to the track. You did something like that? Good to put your specs in your signature, click below in my signature.
What Tacman said:
1. Make sure you have the MONITOR button turned on on the SSD5 Instrument Track 2. Configure your External Device as a NEW KEYBOARD and set it to RECEIVE the midi in from your MIDI cable Im using a Roland TD5 here with SSD5 as well |
Users browsing this forum: jazzundso and 75 guests
