olo
i just want to share my experience with (free) spitfire BBC Symphony Orchestra Discover vst library asus laptop using win 10 pro ryzen 7 4800h 2.9 mhz 16 gb ram studio one pro 5.4.0 (now 5.4.1) preamble: with bbc so discover installed, via spitfire audio app i opened new song in studio one added instrument track selected bbc so discover as an instrument and selected my arturia minilab as midi input clicking on (small keyboard) instrument icon on the track bbc so discover instrument window would pop-up and instantly completely froze studio one had to use ctrl+alt+delete (task manager) to close the studio one repeatedly frozing, no exception then i startup studio one with plugin manager option click-and-drag bbc so discover to disabled plugins since i also have spitfire labs (free also) i checked if this (vst) library works it did work, and not only that, bbc so discovery started to work just normally, as one would expect restarted studio one, for curiosity sake and at startup bbc so discovery is listed as disabled nevertheless the same one bbc so discover works normally weird thing hope this helps someone with same issue have fun aum s love nia |
There's an issue with Windows Scaling and the BBC SO plugin, with Studio One 5.
The fix, per Spitfire Audio, is to right-click the S1 icon to get Properties, select the Compatibility tab, click "Change High DPI settings", check the "Override High DPI scaling behavior" option, and select "System (enhanced)" from the "Scaling performed by" drop menu. |
Users browsing this forum: webhamster and 86 guests
