I've managed the MIDI basics of hooking up my synths / drum machines in/out of Studio One OK, but am now looking to control my Elektron Model Cycles sequences via Studio One.
Presently, I can select each separate track (instrument) by selecting the corresponding MIDI out channel in Studio One. However, regardless of the out-channel selected, pressing play automatically triggers the Model Cycles to play a whole pattern on each whole bar. What I'd like to do, is trigger and stop sequences (either whole patterns or each separate track) at specified points in Studio One, but I can't figure out how to do this. Are there any other Model Cycles (or any groovebox users) who know how to do stuff like this? Sometimes, I find the groovebox workflow easier to write with, rather than in DAW. But I also want to be able to utlise those patterns when putting full tracks together. |
You're running it as a slave right now?
Turn CLK IN on and make sure you're sending midi clock from S1. Noticed about 3 pages of midi settings in their manual: Might go through them, sound interesting. 12.3.1 SYNC Controls how Model:Cycles receives and sends MIDI clock and transport commands. Use LEVEL/DATA to browse and change the settings. CLK IN will, when set to ON, make Model:Cycles respond to MIDI clock and MIDI transport messages sent from external devices. CLK OUT will, when set to ON, make Model:Cycles transmit MIDI clock and MIDI transport messages. PCH IN will, when set to ON, make Model:Cycles respond to incoming program change messages, which is useful when wanting to select patterns externally. You set the MIDI channel for the program change messages in the MIDI CHANNELS menu. For more information, please see “12.3.2 IN CHAN” on page 44. PCH OUT will, when set to ON, make Model:Cycles send program change messages when one pattern changes to another. You set the MIDI channel for the program change messages in the MIDI CHANNELS menu. For more information, please see “12.3.3 OUT CHAN” on page 44.
Tacman7 wroteYou're running it as a slave right now? Yes, Model Cycles running as slave, from Studio One as master. I've managed to locate those settings, but currently it plays a whole pattern, from '0' in the Studio One Instrument track. I just need to figure out how to play/stop the Model Cycles patterns at specific points on the Studio One timeline. I don't really need to program pattern changes yet, as I can select those manually. |
Users browsing this forum: adamhajrula, mayerersoff and 66 guests
