There's a problem assigning the CAPS lock to a shortcut.
Epr St wroteMaybe I'm confusing something and I apologize if I've confused you. When you downloaded the update via S1, the file was named with the particular update, 5.4.1 for example. When you download the file from the account, it's simply called Presonus Studio One 5, and i assumed it was the complete installer and not just the update. Check the size of them both. They are likely the same I suspect. As I mentioned I have always downloaded the off-line installer from my account so I have no "update" installer to compare. |
This seems to be the only way I can post anything here -
I have just parachuted into the middle of this chaos and I would really appreciate it if someone could show me how to get Studio One 5 to recognize my microphone. I dont know one thing about any of this and I dont even know where to start. I was under the impression that I use this Audiobox USB96 to plug a mic into, and then Studio One is basically a recording board. I am so ignorant I do not even know this. I can record analog, but this app/program/computer/MIDI recording is all new to me. I joined Sphere, but since I cant even get a mic to work, Im thinking joining Sphere was a bit pre-mature. |
Hi Andrew.
Welcome to the Forum! Please post in the Audiobox USB section of the forum. viewforum.php?f=164 Please download and read the owner's manual that came with your Audiobox. The Quick Start section should help you get started. Thanks. |
sedrickgomis wroteplugins are missing, I've tried all the redirecting, rescan and reseting blacklist... ive tried everything ??!!!?!?!??!?!?! anyone else have this issue ? I have found this as well, and tried all sorts of things. I then finally noticed that a plugin that wasn't working had a space in its file name, whereas the other plugins did not. Removing the space from the file name made the plugin load. On my way to the bug report section to file it now. |
Recording audio with Macbook Pro M1 + Quantum + newest S1 release + newest UC release (still) creates random digital glitches. Glitches happen not that often with ARM-version of S1 (buffer size not affecting how often they happen), whereas Rosetta version of the newest S1 is full of pops and clicks at reasonable buffer sizes (still at least at 256). Using 5.3 does not introduce pops and clicks but glitches are still present in recorded audio. Reverting to UC 3.5.2 solves that problem BUT creates a new one: If Quantum is powered off and disconnected, the next time I connect and power it on, it is not visible as an audio device. Powering off and on forces Macbook to crash and restart automatically. My "fix" has been to restart my Macbook before connecting it to Quantum.
Ticket opened and I hope this issue gets resolved fast since otherwise the latency and low cpu is a dream come true! |
soundsinthehead wroteRecording audio with Macbook Pro M1 + Quantum + newest S1 release + newest UC release (still) creates random digital glitches. Glitches happen not that often with ARM-version of S1 (buffer size not affecting how often they happen), whereas Rosetta version of the newest S1 is full of pops and clicks at reasonable buffer sizes (still at least at 256). Using 5.3 does not introduce pops and clicks but glitches are still present in recorded audio. Reverting to UC 3.5.2 solves that problem BUT creates a new one: If Quantum is powered off and disconnected, the next time I connect and power it on, it is not visible as an audio device. Powering off and on forces Macbook to crash and restart automatically. My "fix" has been to restart my Macbook before connecting it to Quantum. This problem was resolved with the very fast help of support, thanks! It was a case of properly uninstalling UC and it's drivers (by dropping UC to trash from applications-folder) and then a fresh new install. Works like a charm. Except Acustica-plugins crash, but I feel the blame is on Acustica. |
Apologies up front if this is the wrong place to post something like this but there does not appear to be any discussion on the forums whatsoever about the announcement made 1.11.2021 that Presonus are to merge with Fender. I guess I'm a half empty glass kinda guy but we gammon invalids cannot help thinking about Gibson and Cakewalk traipsing down the aisle back in the day and how well that turned out....
https://www.kvraudio.com/news/fender-musical-instruments-corporation-signs-definitive-agreement-to-acquire-presonus-audio-electronics-inc-53190 |
lfo2k wroteDear developers, this bug exits since 1880, please fix it. I switched from x86 to MacBoook Pro 2021 and it even chases me on macOs. The developers never or rarely come to the forum. it is a user forum. Open a new discussion topic, and submit a ticket to PreSonus. |
lfo2k wroteDear developers, this bug exits since 1880, please fix it. I switched from x86 to MacBoook Pro 2021 and it even chases me on macOs. Double click - "send line" thats it. Problem solved. |
If an individual send line is out of whack with the others, hold shift and you can adjust just one channel send border line only. Once you move it to where the others are, it usually jumps in with them.
Hi Community,
Is someone noticed some randomized "clics or pops" when you work on your sessions ? When I work on my sessions on S1 5.4.1, whatever the size of the project, I hear that often. I'm scared about bouncing the tracks with that. My buffer is 512 or 1024 and the cpu meter is normal. I work on Mac Weird for me... Is someone has the 666 peak issue too ? It happens to me a lot too... I have to put a limiter in order to protect my speakers and my ears. |
lfo2k wroteDear developers, this bug exits since 1880, please fix it. Man, S1 must be the oldest DAW on the planet! |
Users browsing this forum: No registered users and 104 guests
