52 postsPage 2 of 3
1, 2, 3
There's a problem assigning the CAPS lock to a shortcut.
Studio One Pro 6.6 64 bit, macOS Monterey 12.6, 14" MacBook Pro M1 (2021),16gb ram, 512 SSD, 8-core CPU
SkipNo Beet
by bruceqld on Wed Oct 27, 2021 4:06 pm
Epr St wroteMaybe I'm confusing something and I apologize if I've confused you. When you downloaded the update via S1, the file was named with the particular update, 5.4.1 for example. When you download the file from the account, it's simply called Presonus Studio One 5, and i assumed it was the complete installer and not just the update.
Check the size of them both. They are likely the same I suspect. As I mentioned I have always downloaded the off-line installer from my account so I have no "update" installer to compare.
Studio One 5.11 Pro, Win 10, Asus ROG i7, 32 Gb Ram, SSD, RME Fireface UFX, X32, Atom, Faderport USB
by ryanm1 on Mon Nov 01, 2021 9:21 am
Is there still an problem with plug in delay compensation on buses? Have a issue with Sonnox doubler on a bus in parallel.
by sedrickgomis on Mon Nov 01, 2021 8:37 pm
plugins are missing, I've tried all the redirecting, rescan and reseting blacklist... ive tried everything ??!!!?!?!??!?!?! anyone else have this issue ?
by bartwilkus on Tue Nov 02, 2021 4:21 pm
Hi, just wondering, does Studio One have mouse knob control anywhere? I really dislike the "linear" knob control and would prefer it to be "circular". Thanks!
by andrewhogue1 on Fri Nov 05, 2021 2:35 pm
This seems to be the only way I can post anything here -
I have just parachuted into the middle of this chaos and I would really appreciate it if someone could show me how to get Studio One 5 to recognize my microphone. I dont know one thing about any of this and I dont even know where to start. I was under the impression that I use this Audiobox USB96 to plug a mic into, and then Studio One is basically a recording board. I am so ignorant I do not even know this. I can record analog, but this app/program/computer/MIDI recording is all new to me.
I joined Sphere, but since I cant even get a mic to work, Im thinking joining Sphere was a bit pre-mature.
Intel Core i9-10900X 10-Core 3.7GHz (4.5Ghz TurboBoost)
MSI X299 Pro Motherboard
32GB Corsair Vengeance 3000Mhz (4x8GB)
NVidia 8GB GeForce RTX 2080 Super
2TB Samsung 870 QVO Series
Corsair 750X RMX Series Plus Gold Power
Sound Blaster AE-5 Plus
by Bbd on Fri Nov 05, 2021 4:01 pm
Hi Andrew.
Welcome to the Forum!
Please post in the Audiobox USB section of the forum.
viewforum.php?f=164
Please download and read the owner's manual that came with your Audiobox. The Quick Start section should help you get started.
Thanks.
Bbd
by jbox5 on Thu Nov 11, 2021 3:16 am
sedrickgomis wroteplugins are missing, I've tried all the redirecting, rescan and reseting blacklist... ive tried everything ??!!!?!?!??!?!?! anyone else have this issue ?
I have found this as well, and tried all sorts of things. I then finally noticed that a plugin that wasn't working had a space in its file name, whereas the other plugins did not. Removing the space from the file name made the plugin load. On my way to the bug report section to file it now.
by ehabmohammed1 on Mon Nov 15, 2021 3:41 am
waves v13 doesn't work in windows 11
by gregghart on Mon Nov 15, 2021 7:16 am
Yes they do.
And it's officially supported.
https://www.waves.com/support/waves-v13 ... -questions
https://www.midiboy.com
https://gregghart.bandcamp.com
by soundsinthehead on Mon Nov 15, 2021 2:14 pm
Recording audio with Macbook Pro M1 + Quantum + newest S1 release + newest UC release (still) creates random digital glitches. Glitches happen not that often with ARM-version of S1 (buffer size not affecting how often they happen), whereas Rosetta version of the newest S1 is full of pops and clicks at reasonable buffer sizes (still at least at 256). Using 5.3 does not introduce pops and clicks but glitches are still present in recorded audio. Reverting to UC 3.5.2 solves that problem BUT creates a new one: If Quantum is powered off and disconnected, the next time I connect and power it on, it is not visible as an audio device. Powering off and on forces Macbook to crash and restart automatically. My "fix" has been to restart my Macbook before connecting it to Quantum.
Ticket opened and I hope this issue gets resolved fast since otherwise the latency and low cpu is a dream come true!
by soundsinthehead on Mon Nov 22, 2021 2:39 am
soundsinthehead wroteRecording audio with Macbook Pro M1 + Quantum + newest S1 release + newest UC release (still) creates random digital glitches. Glitches happen not that often with ARM-version of S1 (buffer size not affecting how often they happen), whereas Rosetta version of the newest S1 is full of pops and clicks at reasonable buffer sizes (still at least at 256). Using 5.3 does not introduce pops and clicks but glitches are still present in recorded audio. Reverting to UC 3.5.2 solves that problem BUT creates a new one: If Quantum is powered off and disconnected, the next time I connect and power it on, it is not visible as an audio device. Powering off and on forces Macbook to crash and restart automatically. My "fix" has been to restart my Macbook before connecting it to Quantum.
This problem was resolved with the very fast help of support, thanks! It was a case of properly uninstalling UC and it's drivers (by dropping UC to trash from applications-folder) and then a fresh new install.
Works like a charm. Except Acustica-plugins crash, but I feel the blame is on Acustica.
by iainmcculloch on Fri Nov 26, 2021 8:08 pm
Apologies up front if this is the wrong place to post something like this but there does not appear to be any discussion on the forums whatsoever about the announcement made 1.11.2021 that Presonus are to merge with Fender. I guess I'm a half empty glass kinda guy but we gammon invalids cannot help thinking about Gibson and Cakewalk traipsing down the aisle back in the day and how well that turned out....
https://www.kvraudio.com/news/fender-musical-instruments-corporation-signs-definitive-agreement-to-acquire-presonus-audio-electronics-inc-53190
Windows 10 Home (64 bit) : Intel(R) Core (TM) i7-6700HQ CPU @ 2.60GHz
Installed RAM: 16GB
Omen by HP Laptop
NVIDIA geForce GTX 960M
RMI Babyface Pro USB soundcard
Behringer UMX490 MIDI Controller
by bartbalint on Sat Nov 27, 2021 9:45 am
There have been several threads on this topic. here is one:
viewtopic.php?f=151&t=46739&hilit=fender
Studio One v6.5, Win11 latest build, Quantum2, Huion Tablet, ATOM, GR55, HPD-20, iRigKeys, Mackie Big Knob, Elgato StreamDeck+, 8-)
by lfo2k on Mon Nov 29, 2021 3:12 pm
Dear developers, this bug exits since 1880, please fix it. I switched from x86 to MacBoook Pro 2021 and it even chases me on macOs.
Create a template with a couple of channels, save, close S1, start S1, load template and voila:
:roll:
by patricemazmanian on Tue Nov 30, 2021 1:09 am
lfo2k wroteDear developers, this bug exits since 1880, please fix it. I switched from x86 to MacBoook Pro 2021 and it even chases me on macOs.
:roll:
The developers never or rarely come to the forum. it is a user forum.
Open a new discussion topic, and submit a ticket to PreSonus.
S1 pro 6 -Vienna Ensemble Pro - Melodyne - Notion 6 - Win10 - jBridge 1.65 - Motherboard ASUS Z87-K - i7 4770K 3.5Ghz, 32 Go RAM - GeForce GT 610 1024MB - Audio interface RME Hammerfall multiface II - Faderport - ADAT Interface Focusrite Scarlett OctoPre - EWQL hollywood-orchestra...
by pawelhebda on Wed Dec 01, 2021 3:02 am
:roll:
Double click - "send line" thats it. Problem solved.
SO 6.5.2, Macbook Pro M1 - Mac OS 12.7.3, iMac Pro - Mojave. UA Apollo, UA Twin... and lots of other studio gear.
by Jemusic on Thu Dec 02, 2021 3:19 am
If an individual send line is out of whack with the others, hold shift and you can adjust just one channel send border line only. Once you move it to where the others are, it usually jumps in with them.
by Modular13 on Thu Dec 02, 2021 5:07 am
Hi Community,
Is someone noticed some randomized "clics or pops" when you work on your sessions ?
When I work on my sessions on S1 5.4.1, whatever the size of the project, I hear that often.
I'm scared about bouncing the tracks with that.
My buffer is 512 or 1024 and the cpu meter is normal. I work on Mac
Weird for me...
Is someone has the 666 peak issue too ? It happens to me a lot too... I have to put a limiter in order to protect my speakers and my ears.
by Area 52 on Fri Dec 03, 2021 5:10 am
lfo2k wroteDear developers, this bug exits since 1880, please fix it. :roll:
Man, S1 must be the oldest DAW on the planet! :shock:
Studio One Professional 6.6
Windows 11 Pro x64, Intel Core i7-13700F, 16GB RAM, nVIDIA GeForce RTX 4060 Ti.
RME FireFace UFX II, Steinberg UR28M, Steinberg CC121, Allen & Heath QU-32, Yamaha DTX 700 e-drums, Yamaha MX61 synth, Sennheiser HD 600, Mackie HR824..
52 postsPage 2 of 3
1, 2, 3
Users browsing this forum: AAV, garyshepherd, jordanslator and 60 guests
