Dear Studio One users,
the new fall update Studio One version 5.4.1 is available now. Maintainance for even better workflow in your DAW. Have a beautiful autumn! Ari ____________________________________________ Version 5.4.1 Release Notes (October 14, 2021): The following issues have been fixed: ● [Apple Silicon Native] Tuner shows incorrect results ● [ATOM SQ] Fixed page numbers for Song, Instrument, and Editor buttons ● [macOS] Touch event is offset in plug-in select menu ● [Note Editor] Tab to next note not working consistently ● 32-bit float recording from Capture shows up as 16-bit in Studio One ● Alt+Drag in arrangement intermittently crashes S1 ● BPM from WAV file not properly applied to audio part ● Can’t drag WAV files to browser to export events with FX ● Cancel mixdown keeps rendered part ● Crash when closing plug-in editor via touch ● Crash with Acustica Audio N4 plug-in ● "Cursor follows edit position” option fails when dragging chords from the chord track to the arrangement ● Dragging notes from note editor to arrangement delivers unexpected results ● Dragging time-stretched audio event with detected chords to instrument track creates event with wrong length ● Dragging Splitter from browser search result shows unwanted behavior ● Higher audio monitoring latency reported in certain cases ● Impact XT inside a multi-instrument creates unwanted noise ● Note On not sent to MIDI outputs when MPE enabled ● Pipeline ‘ping’ doesn’t work when transport is stopped ● Potential crash on system shutdown when Studio One is still open ● Scores from Notion using Jazz font are displayed incorrectly ● Some automation parameters may be linked to the wrong track with bus automation ● SoundCloud browser tab occasionally stays empty ● With Plug-in Nap active, reverb tail is cut from certain AU plug-ins ● With Show Page in Perform View, pressing space bar to play/stop doesn’t work when Setlist is in focus
Users browsing this forum: JohHuisman and 60 guests
