I can't figure out how to insert a pattern right at the beginning of a measure. Currently it just places it wherever my cursor happens to be, which is never at the right spot. I tried the "Snap To" feature with no luck. You would think this would be the default behavior, but there I go "assuming" again (and we all know what happens when we do that ).
I'm sure there's a very simple way to do this, but I haven't found it yet. And I know, I know => Thanks in advance! Paul |
What I'm essentially looking for is a way to click in the timeline and insert patterns in time or copy an existing pattern(s) and then paste that at the end. Doesn't seem like a big ask to me, but I'm still learning my way around the software so I'm at a roadblock at this point. It's gotta be possible...
Just in case I haven't been clear enough, current patterns that I've inserted are not in time (a fraction after the last pattern) which totally jacks up the flow of the song. |
UPDATE: Okay, while I didn't figure out how to insert a pattern at exactly the correct point, I DID figure out how to "nudge" it there.
• Select the Pattern you want to move • Hold the ALT/Opt key • Use the Left and Right arrows to move the pattern to the correct point While this is less than ideal, at least it allows me to continue on until I figure out a better way to do it. If you know a better way, please post below. |
This thread has migrated here:
https://forums.presonus.com/viewtopic.php?p=271421#p271421 |
Users browsing this forum: No registered users and 87 guests
