Hiya,
So I've been trying out S1 via Presonus Sphere for over a month now. I've been getting irritated with Cubase, so I thought I'd give it a shot. It's mostly been really awesome, although I have had these annoying issues: - (With 'Select Part Automation with Notes') Sustain pedal data not selected along with notes if sustain pedal tab not showing - Sustain pedal data for track not working if S1 is playing and monitoring for track toggled. Need to restart playback and will then work again (tested with VSTs like Pianoteq 7 and EZKeys) - Sometimes have had sustain pedal data not be recognised at all when moving a part to the main window from a scratch pad. - (With 'Select Part Automation with Notes') Sustain pedal data not stretched along with key data is when using stretch operation. - I created a 'Re-record' macro and it often doesn't work. Will sometimes delete the whole part or just stop (amongs other weirdness). This maybe occurs only when the key editor is open. - Audio export seems broken for me when I use CTC. Cheers, J |
Users browsing this forum: αlphatonez and 87 guests
