1 post
Hiya,
So I've been trying out S1 via Presonus Sphere for over a month now. I've been getting irritated with Cubase, so I thought I'd give it a shot.
It's mostly been really awesome, although I have had these annoying issues:
- (With 'Select Part Automation with Notes') Sustain pedal data not selected along with notes if sustain pedal tab not showing
- Sustain pedal data for track not working if S1 is playing and monitoring for track toggled. Need to restart playback and will then work again (tested with VSTs like Pianoteq 7 and EZKeys)
- Sometimes have had sustain pedal data not be recognised at all when moving a part to the main window from a scratch pad.
- (With 'Select Part Automation with Notes') Sustain pedal data not stretched along with key data is when using stretch operation.
- I created a 'Re-record' macro and it often doesn't work. Will sometimes delete the whole part or just stop (amongs other weirdness). This maybe occurs only when the key editor is open.
- Audio export seems broken for me when I use CTC.
Cheers,
J
1 post
Users browsing this forum: No registered users and 32 guests
