Potential Defect (Studio One v5.40) - Cannot reorder processes within Audio Batch Convertor process rack
Posted: Thu Sep 23, 2021 1:37 pm
When testing several new "process racks" in ABC - I have discovered I cannot select/drag/move a process (effect) that is in the rack and do this (from the ABC manual) -
"Once loaded into the Process Rack, you can change the order of the plug-ins by dragging and dropping them into the desired processing chain"
This worked as designed in 5.3.x but there is no facility to move a process plugin up or down in the rack when using ABC with S1 v5.40.
I have submitted a ticket and it would be great if anyone who uses ABC with S1 v5.40 can confirm the same.
Cheers
VP
Cheers
VP
