Fadeout sounds abruptly ended
Posted: Wed Sep 22, 2021 11:03 am
by makrelguf
Hi
My fadeouts seem to end kinda abruptly.
The very last part doesn't sound smooth, and I can hear the point where the fade ends (from sound to no-sound difference seems too big).
No plugins used, just using either fade on track events or on the main fader, seems like same result.
How can I make smoother fadeouts easily?
Thanks
Re: Fadeout sounds abruptly ended
Posted: Wed Sep 22, 2021 1:19 pm
by Tacman7
Is this audio or midi instruments?
Automating the volume of audio is a way. Maybe some screen shots of what you have setup and what you're wanting to do.
Lot of vids about fade.
https://www.youtube.com/watch?v=qCqRzHwBjyoGood to put your specs in your signature, click below in my signature.
Posted: Wed Sep 22, 2021 1:27 pm
by makrelguf
It's audio.
Studio One doesn't fadeout smoothly by default.
The volume at the very end of a fade is not as close to zero as it should be.
On every project in every fade so it's a general issue, I didn't have that issue in Cubase or Logic
Posted: Thu Sep 23, 2021 10:34 am
by mikemanthei
By default, fadeouts are linear. It sounds like you might be happier with an Exponential fade. Grab the handle in the middle of the fadeout and pull it down. It will speed up the beginning of the fade and slow down the end so it will "fade" into silence a bit more subtly.
Posted: Sat Sep 25, 2021 6:47 am
by stefanrauch1
Posted: Sat Sep 25, 2021 7:37 am
by Lokeyfly
mikemanthei wroteBy default, fadeouts are linear. It sounds like you might be happier with an Exponential fade. Grab the handle in the middle of the fadeout and pull it down. It will speed up the beginning of the fade and slow down the end so it will "fade" into silence a bit more subtly.
Yes, that
or even create an automation fade. Either way makrelguf, there's different options.
Note: even if your linear simplest fade is ending abruptly, it could be due to a number of things from the input or output gain, impedance, possibly a compressor or some processing as an outside guess. Point being, make sure you are getting smooth fades first, weather they're to your liking or not.
Posted: Mon Sep 27, 2021 11:12 am
by makrelguf
stefanrauch1 wroteyou might want to check out this:
https://www.airwindows.com/purestfade/
PurestFade seems to do the trick nicely. Thanks
