I have run the installer from Nektar, and I am seeing a midi signal at the midi icon on the bottom right, but no sound, and no DAW control, and no signal to impact XT. I cannot seem to figure out what I am doing wrong. I set the configuration to channel 1 under external devices. It is the only external device hooked up. I have it hooked up with both a standard midi cable and the USB cable. Any help would be appreciated. Thanks
Athena 4U Chassis i7-3770K Processor 5.0GHz(OC)|Gigabyte Z77X-UD3H|2 X 4GB Patriot Viper Extreme DDR3-1600|2GB Crucial SSD|SanDisk Extreme Pro 500GB SSD|SIIG 3 Port 9 wire Firewire Card|VIA 3 Port USB 2.0 Card|LG DVD/CD Drive|Gigabyte GTX 750 1GB(OC)|S1 Pro 4|D-Link DIR-615|Edirol UA-700|AB1818VSL |AS-900T IE Monitor System|Studiolive 24 S3|Studiolive RM16L|Alesis SR18|Digitech Vocalist Live Pro|Behringer DSP2024P|Nektar LX88+|Alesis Strike Force E-Drums|
Lequarius wroteI have it hooked up with both a standard midi cable and the USB cable. Which one do you want to use? You pick one then set both devices to it. Some keyboards have to be set to one or the other in the keyboard, not sure about yours... The installer should have made two devices, a keyboard and a controller. That's what it did for my impact. I never had to do anything to them, other than point them to my input. It will just be there as one of the inputs available for an instrument track:
I have checked the settings, and MIDI data is definitely being received. The MIDI input window confirms this from every fader, dial, knob, button, and key, on the LX88+. I'm betting I have the inputs or something screwed up. I have checked but cannot see anything wrong. I have included screenshots of the MIDI input window, and the monitor with instrument window open. I hope this helps. Thanks.
I have used an LX88 for years. Can you post your external devices window?
Users browsing this forum: No registered users and 50 guests
