Hello Everyone!
I am stuck with a nasty problem and can't seem to find a solution nor a workaround to have it work, I was wondering if someone has a solution for this..
I have recently bought a monogram console, for those of you who don't what it is, it's simply a modular midi controller(it's more than that really) but for Music you can assign faders for example to any midi cc values or assign key strokes to keyboard shortcuts or simply control your parameters through midi mapping.
https://monogramcc.com/shop/
The problem is, I have my faders assigned to CC 1, 2 and 11 and S1 simply doesn't receive anything from the controller..noting that this works flawlessly when I tried it with Logic Pro and Ableton Live without even setting anything in the DAWs.
I failed miserably to make this work in S1, I tried setting it up as a controller and even as Mackie Control receiving from the monogram port and still nothing.
The only thing that gave me a different result when I tried setting it up as an instrument then when I touched the fader studio 1 received midi cc signals from the faders but I didn't understand what those were as those values were only related to this instrument and and this instrument number and didn't change anything or send those midi cc values globally to the virtual instruments I was using..Sorry this is a little difficult to explain , if anyone is interested in this specific point I can always post a screenshot.
Just to be clear I am NOT trying to assign specific parameters in synths to those faders which I would usually do through control link and midi learn .. I want them to behave as a global midi cc values exactly like mod wheel in your midi keyboard for example.
I just don't understand how can for example a Komplete Kontrol keyboard send midi cc values like 1 and 11 and S1 receives them flawlessly but when I use the faders that are also set to the same values nothing happens in S1 yet other DAWs receive the midi cc information no problem....
If anyone knows how to fix this or has a workaround please let me know it will be very much appreciated, I hit a dead end here.
Thank you all in advance!
Hassan
by Tacman7 on Thu Sep 16, 2021 6:37 am
hassanelshafei wroteI am NOT trying to assign specific parameters in synths to those faders which I would usually do through control link and midi learn .. I want them to behave as a global midi cc values exactly like mod wheel in your midi keyboard for example.
Did you create a keyboard device for it? That should make it work like you want.
Studio OnePro5 Melodyne Studio
Studio Computer - Nectar Impact LX25+
Win10 i7 7700k 16gb ram 1TB SSD AsusH270M-PLUS interface:StudioKonnekt 48
Kitchen Computer - Microkey Air Eris 3.5
Win10 Ryzen 5 3600 - Radeon RX 590 - 512GB SSD interface: Motu M2
by hassanelshafei on Sun Sep 19, 2021 7:18 am
Good to put your specs in your signature, click below in my signature.[/quote]
Hello Tacman,
Thank you for your reply! This is exactly what the guys at Monogram suggested and this was their exact wording :
"The solution to this should be to remove Monogram from the devices menu and re-add it as a MIDI Keyboard this time. Studio One has a bit of a strange setup where it assumes the basic MIDI CC commands are on a keyboard, not a control surface."
I posted it in case anyone had a smilier problem. I believe that this should be considered as a bug and not a missing feature as all major DAWs received the Midi CC no problem without even trying to setting the device in any specific way.
Oh and I am not really sure how to put my specs in my signature .. :lol:
Users browsing this forum: nikolaospitloglou and 29 guests
