147 postsPage 6 of 8
1 ... 3, 4, 5, 6, 7, 8
snb1 wroteI did. It also happen to me only once thus far.
Thanks snb1 well that's two of us let's see if anyone else has had the problem and more importantly if there is a suggested fix for it. :)
Best,
Gerry
People who can't dance always blame the band.
https://soundcloud.com/gerry-cooper-855281238
Studio One 5 Pro. Windows 10 64 Bit 4 GB Intel 2 Quad Q 9950 @ 2.83 GHz . Focusrite Scarlett 2i2 3rd Genereation, NI Komplete Kontrol S61, NI Komplete 12 Ultimate, Izotope Ozone 5 and 8. Yamaha HS 80 Monitors.
by maschinenwart on Thu Sep 23, 2021 5:32 am
Quietly wrote...Anyone else had this problem? https://forums.presonus.com/viewtopic.php?p=272202#p272202
Thanks in advance,
Gerry
...I have also experienced this problem several times :thumbdown:
best
Eric
:: iMac Pro
:: MacBookPro
:: macOS Big Sur 11.6
:: UAD Apollo 8 Ouad Thunderbolt (9.14.7)
:: StudioLive 16R Series III
by PreAl on Thu Sep 23, 2021 5:39 am
^ I suggest stating here your "received from" and "send to" configuration, how in/out for the track is set up, and what plugins and synths you are using on the track next time you get the issue. More info could nail this issue down.
Studio One Pro 5, Faderport Classic (1.45), Atom Pad, Atom SQ, Presonus Studio 26c, Focusrite Saffire Pro 40, Maschine Studio, Octapad SPD-30, Roland A300, Windows 10 Pro 64 bit, also running it on Mac OS Catalina via dual boot (experimental).
Intel i9 9900K, 32GB RAM,
EVGA Geforce 1070 (Nvidia drivers).
by Quietly on Thu Sep 23, 2021 8:31 am
PreAl wrote^ I suggest stating here your "received from" and "send to" configuration, how in/out for the track is set up, and what plugins and synths you are using on the track next time you get the issue. More info could nail this issue down.
This has happened to me when using Kontakt and or Komplete Kontrol. I mention that because at times 5.4 appears to grunt when unloading either of these plugins from the Performance Meter. Being very low on CPU I quickly convert instruments into rendered audio and remove vst instruments. In either case this has only occured since installing 5.4. Lastly I have checked I have the latest drivers installed graphics card etc.
by PreAl on Thu Sep 23, 2021 8:41 am
I assume you've updated to the latest via native access?
So that's a plugin with multiple outputs, how are the midi inputs/outputs configured per track? How is the device configured? Do others have the same issue with the same plugin or another plugin multiple outputs (or even a single output). Please specify how it's set up for input/output.
by Quietly on Thu Sep 23, 2021 10:43 am
You assume correctly on being updated via Access LOL Configuration is fine and I was not using multiple outlets when this occured. I went into View, Plug-In Manager and noticed a yellow warning sign with the request to Remove Plug-In Settings and then restart S1, which I did. Not sure if this has anything to do with it but up to now running fine and no sticking midi notes so fingers crossed. If it occurs again I will be back.
Best and thanks for your interest and help.
Gerry
It's back and always sticks on E or a chord with an E in it. OK there are work arounds but its still a pain.
by PreAl on Thu Sep 23, 2021 11:43 am
PreAl wrote I suggest stating here your "received from" and "send to" configuration, how in/out for the track is set up, and what plugins and synths you are using on the track next time you get the issue. More info could nail this issue down.
Quietly wroteThis has happened to me when using Kontakt and or Komplete Kontrol. I mention that because at times 5.4 appears to grunt when unloading either of these plugins from the Performance Meter. Being very low on CPU I quickly convert instruments into rendered audio and remove vst instruments. In either case this has only occured since installing 5.4. Lastly I have checked I have the latest drivers installed graphics card etc.
PreAl wroteI assume you've updated to the latest via native access?
Quietly wroteYou assume correctly on being updated via Access LOL Configuration is fine and I was not using multiple outlets when this occured. I went into View, Plug-In Manager and noticed a yellow warning sign with the request to Remove Plug-In Settings and then restart S1, which I did. Not sure if this has anything to do with it but up to now running fine and no sticking midi notes so fingers crossed. If it occurs again I will be back.
Gerry
With respect I was not asking if your configuration is fine, I'm asking what specifically is your in/out configuration is for device and channel so that if there is a bug it can be reproduced. Details help, people's workflow are different.
Good advice you've made though, perhaps those with the issue can do what you did.
by snb1 on Thu Sep 23, 2021 6:19 pm
Best,
Gerry
I found that closing and opening the editor does the trick for me. Deleting the Event and undoing it worked for me too.
Studio One Pro 5.4.1 64 bit, macOS Big Sur 11.3.1, MacBook Air M1 (2020), 8gb ram, 256 SSD
SkipNo Beet
by tristanmendoza1 on Thu Sep 23, 2021 7:32 pm
soundsinthehead wrote
ianaeillo wroteAnyone having issues with updating universal control? Mine no longer shows my quantum nor does it connect to my app but the interface still functions as expected.
I had no problems installing the new version and updating Quantum driver. Noticed serious glitches though in the incoming signal, when recording something through Quantum to the newest version of S1. Both Silicon and Rosetta -versions of S1 did glitches. Stepped back to previous versions with UC and S1, no glitches anymore. Put me on the waiting list of the next update...
So I don’t have Quantum (Apollo user) but I think I know what you’re talking about. Any output from Studio One is extremely distorted. I was on 5.3 running everything smoothly and as soon as I was on 5.4 any audio, even in a fresh session and listening to samples from the browser at a low volume is distorted.
Support was honestly a pretty unpleasant experience.
Has anyone come up with a solution? I’m on 5.3 again but I’m wondering how common this is and if there is a way to fix it on our end.
by tristanmendoza1 on Thu Sep 23, 2021 7:50 pm
So I updated both of my systems to 5.4 recently. One computer had distortion on any kind of output from Studio One, the other didn’t have distortion at all but it seemed to recall sessions incorrectly. Entire audio and MIDI tracks were off time, restarting S1 fixed it sometimes
Has anyone heard of anything like this ever happening at all? I haven’t, and I’m honestly confused and frustrated. Some of my sessions sounded like complete train wrecks. I know some people are probably thinking “this kids stupid, it’s user error” and I would think that too if someone told me this. I’m telling you though, songs I’ve already done test mixes of were complete train wrecks.
Does anyone know anything about this? I feel like I’m losing my mind.
Tech support sent me a link to a blog about CPU optimization, told me to revert back to 5.3 and I haven’t heard anything since. I asked them if this is an issue for anyone else or if the dev team is aware, but I think they closed the support ticket :thumbdown:
by patricebrousseau on Thu Sep 23, 2021 8:30 pm
This update looks a bit buggy. Those bugs and the C’s octave bug: viewtopic.php?f=151&t=46327
by PreAl on Fri Sep 24, 2021 1:56 am
Sounds like your drivers. The latest versions of Windows 10 (via windows update) is often requiring people to update their ASIO drivers. Saffire Pro for instance now has compatibility problems and a new driver won't be released.
by Quietly on Fri Sep 24, 2021 2:36 am
Best,
Gerry
Problem has not come back although I cannot gurantee this is the solution but it has worked so far. Yes there are several ways of solving it but it can get annoying if it happens frequently. :shock: :)
by PreAl on Fri Sep 24, 2021 3:33 am
tristanmendoza1 wroteSo I updated both of my systems to 5.4 recently. One computer had distortion on any kind of output from Studio One, the other didn’t have distortion at all but it seemed to recall sessions incorrectly. Entire audio and MIDI tracks were off time, restarting S1 fixed it sometimes
Also (see my previous post) have you tried increasing your buffers and playing with all the dropout protection settings? And checked you are on the correct ASIO driver. Sorry for obvious comment.
by tristanmendoza1 on Fri Sep 24, 2021 7:46 am
No worries! You're right, my laptop was the one I was using without an interface and that's the one that was having the audio distortion so your ASIO recommendation sounds about right.
However, my desktop is running on an Apollo Twin mk2, so what would ASIO have to do with it? Buffer settings and drop out protection would seem like a valid recommendation but again this seems unrelated to performance. Entire song sessions we're visibly off time, almost like the session loaded incorrectly. I know that's hard to believe, and I'm trying to think if there's anything I could have done to mess these sessions up so badly but it's way too bad to be an accidental adjustment or oblivious user error. I have a test mix of a song on my phone and the session sounds nothing like it anymore. The only way I could try to describe it is it seems like session data either partially or completely loaded incorrectly.
I'm honestly less upset that it's happening, but more so because it doesn't make any damn sense. You know?
by PreAl on Fri Sep 24, 2021 9:28 am
Buffer and dropout settings is entirely related to performance and even can screw up sync, certainly any form of distortion, configured badly and you can get the symptoms you describe. ASIO drivers perform the best, please also make sure you are on the latest drivers and firmware... Also check out latencymon.
I do appreciate however you are describing what looks like a corrupted project ..
https://help.uaudio.com/hc/en-us/articl ... -Downloads
Edited for clarity.
by Anderton on Fri Sep 24, 2021 10:02 am
FWIW nap is useful for me with hungry amp sims like Helix Native. A lot of times I'll have multiple Helix tracks for specific song sections, e.g., one Helix sound for intro, one for chorus, one for solo. Only one Helix needs to be playing at a time, so nap keeps the other two from drawing CPU. (It also has uses for preset development, but that's of less general interest.)
Digital storefront: craiganderton.com
Free educational site: craiganderton.org
Music: youtube.com/thecraiganderton
Studio One eBooks: shop.presonus.com
by frank.crow on Fri Sep 24, 2021 12:48 pm
Nap Function introduces tons of latency to (only) Slate VMR plugins rendering meters useless.
Mac Mini (Late 2014)
Memory: 16 GB
Presonus. Studio One Pro V5
Presonus Quantum
Line 6. BassPOD XT Pro
Hardware DBX 160a
Hardware DBX 160XT
GA. Comp 2A
GA. Comp 3A
WA76 1176 (clone)
Softube. Console 1 MKII
Presonus. FaderPort & Faderport 8
"God's grace" :D
by frank.crow on Fri Sep 24, 2021 12:51 pm
kisnou wrotePersonally curious about the plug-in nap feature..
If anyone has tried already, I just hope it works well, I'm afraid it may cause some bugs :?
However it seems really cool for those who work in big projects like me.
Latency
I’m getting tons of latency on Slate VMR plugins. My meters are basically useless. So far it seems to be isolated to just those plugins.
Memory: 16 GB
Presonus Quantum
Hardware DBX 160a
Hardware DBX 160XT
GA. Comp 2A
GA. Comp 3A
WA76 1176 (clone)
"God's grace" :D
by Bbd on Fri Sep 24, 2021 2:00 pm
I don't own any Slate plugins so if you are having issues with them, please create a support to get their eyes on this.
Thanks.
Users browsing this forum: robertgray3 and 41 guests
