I'm going a bit overboard into the concept, but just for pointless discussion sake,
Do tracks line up "correctly" if you use the click from a daw (which has latency, no?) and direct monitor the performance on top of that, when blending direct and daw monitoring? I'm guessing building tracks with direct monitoring on top of a latent sound would eventually drift off? Or maybe the benefit is the click is only return latency, so that's closer to direct monitoring. Ok, if you record with direct monitoring, won't the daw's latency compensation throw a wrench into the pot, making it earlier? |
Users browsing this forum: maschinenwart and 43 guests
