I'm having a problem with audio dropouts and crackling noises when selecting my interface as the audio device in S1. It all started when I had to mix a song without my audio interface and I chose Windows Audio as my audio device, since then, everytime I change it to my audio interface it starts to make crackling noises and audio dropouts even when I watch youtube while the project is open. My CPU is at 60/70% and the higher the Buffer size the worse it gets. I have reinstalled all drivers, even windows 10 and s1, but nothing has changed. I also tried other USB ports and other cables, even selecting a hi performance in the power settings. As mentioned, when I choose Windows Audio back again, all seems to work fine, no noises or cracks, just works perfect even with higher buffer sizes.
My specs: Interface: Antelope Audio Discrete 4 Synergy Core Ryzen 7 3700x 16gb RAM 3200mhz 1tb SSD m.2 nvme MB Aorus Elite x570 Thanks |
Could you give us a screen grab of these settings?
So can you lower that block size of 2048?
What are your choices when you click the drop down?
Tacman7 wroteSo can you lower that block size of 2048? When I lower the buffer size to 256, it gets rid of "some" crackling noise but the CPU is almost maxed out and starting to drop out. But same settings using windows audio work perfctly fine |
That interface has control software right?
Is that setup and working? What is windows launcher? I was really wanting to buy one of these for a while...
Tacman7 wroteThat interface has control software right? Yes! Everything is working fine with the Antelope control software. In fact, when I use windows audio, it uses the inputs and outputs of the interface, but it adds LOTS of latency and doesn't allow me to use multiple inputs/outputs. |
Are there latency settings in the control software?
So in windows, do you have the D4 selected to do the sound for windows? I don't think you would want that and the usb asio driver working at the same time. Change that to something else or disable and see if that changes anything.
Tacman7 wroteAre there latency settings in the control software? There are no latency settings in the control software, it has always worked perfect that way, using the interface as the main device for everything, and all of a sudden it all went wrong. I'm starting to think AMD drivers or something else is making interferences... I don't really know what to think, I reinstalled all... The cracks and dropouts also happen in the computer, when I watch youtube, spoti or anything while the project is open Note: I tried using theD4 only for studio one, only for the project song, but still having the same issue. |
Does it get worse if you select 128 block size? I can't work any higher than that for tracking.
An interface only shows you what it's capable of and it has some really low latency settings. I guess that's for use with thunderbolt. You've moved the usb cable to main ports on your motherboard? Tried other ones etc. It may be a win10 usb update or something. It does sound like some sort of conflict/problem beyond setup. I would open a Presonus ticket and one for your interface. They might have some answers or suggestions.
Users browsing this forum: No registered users and 62 guests
