Is there a way to select "All Inputs" as the default choice for tracks that have MIDI inputs?
Thanks! |
I have a default song which opens up every time Studio One boots up. It contains one Instrument track. I have this set for All Inputs. Studio One remembers this. So the Input source for Instrument tracks is as per how you have saved your default track.
If I set this to say one of my controllers instead (and re-save the default of course) then this is how it boots up next time. When you create a new Instrument track the setting for the Input source is usually the default as well. Which in my case is also All Inputs. You do have the option right at this point to change that before a new Instrument track is also created in that window.
Under external devices, check that "use this as my primary device" (or something along that line) is unchecked on all devices.
Toronto, Canada
Project engineer by day, sound connoisseur by night. Main Rig: Windows 11 (21H2) 64-bit, Ryzen 3900x, 32GB RAM, RTX 2060, dual 4K Monitors Presonus 192, Faderport v2, Atom SQ, Akai Advance 49, Keystation 61 mk3, 2x Behringer X-Touch Mini + way too many synths. Mobile Rig: MBP M1/16GB, Atom SQ, IOstation |
The manual states that if you have only one keyboard connected you should check the box that says Use as default Instrument input. I guess that means if you have more than one input source then you should not check this box.
The only way I could get my default Instrument input to be what I wanted was to select the input you want and re-save the default song.
ts-12 wroteI wish it was possible to have "all midi ins" as default, very annoying to always switch inputs on new instrument tracks My sessions are always like this, I didn't do anything special. I have two keyboards and when I select any of the instruments I can play with both without changing a setting. Isn't this the default behavior already?
Using Studio One 6 (Always the latest version)
System i9 9900K, 64GB RAM, 2080TI, 34" 4K Display & 55" 4K Professional Display, Windows 10 Studio I/O Lewitt LCT-440, Yamaha HS7, PreSonus Studio 1824c, Beyerdynamics DT1990, Audio Technica M50X Studio Gear Arturia Keylab 88 MK2, Atom Pad, Atom SQ Instruments Cordoba GK Studio, Takamine GJ72CE, Godin Session, Yamaha F310 R&B Singer / Songwriter / Producer Website |
In "options - external devices" just make sure nothing is set as the default input. The "in" column has a tick if a default input is set.
If there is no default input then any new instrument track defaults to "All Inputs". If there is a default input then new instrument tracks are set to that. I don't think you have to re-save a default song or anything. |
Users browsing this forum: leosutherland and 75 guests
