i've got a loop pedal midi sync'd to S1.
It starts and stops fine, just wondering if there is any way to send CC data to it and more specifically if loop start/stop points will automatically send midi cc data? |
Sure, quickest way is to add the CC you want to send in the midi editor.
Double click a midi event to open it in the editor. There's a plus and minus there to add more lanes and the seagull hides all the cc's. Good to put your specs in your signature, click below in my signature.
You would draw an event the right size then insert some data into the lanes.
Wherever you put the data the message will be sent when the play-marker passes over it. So if that was at the beginning of the loop it should do what you want. I don't think CC's are start and stop Check out message formats: https://www.cs.cmu.edu/~music/cmsip/rea ... i-spec.htm Your looper follows midi clock?
Users browsing this forum: jebbyslonar and 48 guests
