Anyone got a macro that will take a track containing chords and split it into x tracks each containing one line of notes from the chords? This is not the same as explode pitch to tracks.
Imagine I have track 1 filled with triad chords. I want to end up with track 2 with the top note of each triad, track 3 with the middle note of each triad and track 4 with the bottom note of each triad. In realty I'll be using chords of 5 or 6 notes but the principle is the same. At present I'm just duplicating the track x times and then using the select top/bottom notes thing to manually delete the notes I don't want. It's a fairly quick process but prone to human error so a macro would be better. And in case you are wondering about why I do this it's to get a starting point for orchestrating strings - split a 6 note chord across violin, viola, cello and bass. They all need further editing, particularly the higher instruments but the chord notes give a great starting point. |
Users browsing this forum: johndoe313, patrickviens and 96 guests
