Can I export MIDI CC Automation Data From S1?
Posted: Tue Jun 15, 2021 10:22 pm
by michaelmyers1
I want to share a MIDI file with a friend that has the same VST library but uses Logic. Is there a way to export the MIDI CC Data that I've recorded in my studio one session so that he can read it in Logic?
Re: Can I export MIDI CC Automation Data From S1?
Posted: Wed Jun 16, 2021 12:53 am
by Jemusic
I just did a test, recording a midi clip in Studio One and applying mod wheel and pitch bend. I simply exported that and dragged that into Ableton and all that CC info was there.
Don't forget also that Logic is AAF compatible. You can save a complete Studio One song in AAF format and he should be able to import it directly into Logic. Midi files with CC messages and all.
Posted: Fri Jul 02, 2021 7:38 pm
by michaelmyers1
Update on this issue in case any others are following:
MIDI CC Automation will be exported only if it is PART automation. It will not be exported if it is in an Automation Track for an Instrument.
