SOLVED - Copy and replace a note in bongo track
Posted: Sat Jun 12, 2021 1:14 am
by danbredahl
Newbie here..
I have recorded a bongotrack, and some hits are better than others so I want to replace the bad ones with some of the better ones. But no matter how I try to do it - the event I insert pushes the remaining audio to the right. Can someone explain how to avoid this?
SOLVED - Re: Copy and replace a note in bongo track
Posted: Sun Jun 13, 2021 11:31 am
by Trucky
What method are you using to do this?
I use the Range tool to select what I want to copy, followed by pressing [Ctrl][C] then clicking the timeline to where I want to paste and press [Ctrl][V] to paste.
Posted: Sun Jun 13, 2021 12:00 pm
by danbredahl
Thats how I try to do it - I use the toolbar though
Posted: Sun Jun 13, 2021 1:47 pm
by Trucky
Make sure that "Ripple Edit" mode is turned OFF and then try it:
Posted: Sun Jun 13, 2021 2:12 pm
by danbredahl
Thats it - it works:)
