I am wanting to select midi notes using a few different conditions eg select all short notes with high velocity in the range c1 - c3
At the moment I can only do one of those at a time and cant seem to find a method for chaining a few conditions one after the other is there such a method? thanks, Greg
win10, old i5 machine (plenty good enough) S1Pro, Bitwig, Adam A7 monitors
https://greghooper2.bandcamp.com/ |
This is select notes dialog, I usually select all then right click a note then select under musical function/global select notes.
There's quite a few things it does. The default command is select short notes.
thanks - that is the one I have been using as well - but is there any way to select more than one checkbox and parameter - so for example I select only the short notes that have velocity greater than 100
Multiple passes? select the short notes then come back with a velocity selection?
Should be the same results but much more fun.
for sure that can be done but not as good a workflow. Maybe I put in a feature request and also ask Gregor on Youtube
Users browsing this forum: johndoe313 and 92 guests
