Stop Studio One from hogging the sound driver. All other applications are well behaved in that regard. I can run Spotify, my web browser and Windows media player simultaneously and they all play at the same time. But while Studio One is running, I cannot even change the computer volume without problems. If Studio One is lauched before other applications, those applications cannot access the sound driver. If other applications are lauched first, Studio One freezes when I give it focus. Yes, I have tried changing the Studio One settings/parameters (Release audio device on background) to no avail.
It is immensely annoying. Thank you. |
Have you tried the checkbox on the audio setup page?
The release audio device
michelvillemaire1 wroteYes, I have tried changing the Studio One settings/parameters (Release audio device on background) to no avail. Tacman7 wroteHave you tried the checkbox on the audio setup page? What interface are you using? Do you have more than one you can try? I remember I had an interface that didn't seem to communicate with DAWs properly, especially things like changing Buffer Size and releasing the driver |
Missed that!
Do you use HDMI sound also? I notice I can have S1 going and send windows to the HDMI driver. If S1 is the only program you're running does it work then? Like can you play an mp3 file outside of S1? If so then see if there's certain app that causes problems, just a thought. If you have a sound card that came with the computer run windows through that and out to your interface inputs.
What sample rate are you using?
That and what interface? Usually the problem can be corrected with matching sample rates. But there are other issues depending on what interface you're using. Good to put your specs in your signature, click below in my signature.
Does anything change when you select and deselect the device checkbox?
It works for me unchecked.
michelvillemaire1 wroteStop Studio One from hogging the sound driver. All other applications are well behaved in that regard. I can run Spotify, my web browser and Windows media player simultaneously and they all play at the same time. But while Studio One is running, I cannot even change the computer volume without problems. If Studio One is lauched before other applications, those applications cannot access the sound driver. If other applications are lauched first, Studio One freezes when I give it focus. Yes, I have tried changing the Studio One settings/parameters (Release audio device on background) to no avail. I selected windows audio as my interface and solved it
I type in monotone.
Usage of caps, bold, italic, or underline intended as emphasis and not yelling. Yelling comes with angry emoji Always joking around and busting everybody's chops. It's not intended to be insulting OnStage AS800 FET Condenser Mic, SM57, AudioBox iTWO, Shure SRH440 monitoring headphones, CAD monitoring headphones, pair of 5" JBL LSR2325P, Studio One 5 Artist, Windows 10 64 bit HP Envy x360 convertible ***PLEASE speak slowly and dumb it way down. Total n00b here. No clue what I am doing, computer illiterate, and A.D.D.. Rock on, good people! |
This might be better, setting windows audio as an interface in studio one is far from ideal.
Set windows audio to realtek spdif/out..Enable the output device in control panel, make it default. Disable all the other output drivers in windows control panel. Plug in spfif cable into realtek output and put it into the creative sp/dif input (enable the input device in the creative mixer, not in windows control panel!). You can buy spdif cables on eBay for only a few dollars,.maybe creative supplied one. Make sure you set up your creative card so it monitors spdif. Then set up studio one to use the Creative driver (preferably asio). There should be no sample rate conflicts after this..You are using realtek for Windows, and your creative card for studio one. They can operate independently. This works for me for my saffire pro 40 and onboard realtek, hopefully it will work with the creative card. Creative cards in the past haven't exactly been great for recording, it's mainly for gamers, but maybe things have changed. Oh and if you have ASIO4All installed remove it completely.
Selecting windows audio is not a good solution I'm afraid you must use the ASIO drivers.
Today I discovered that Windows 10 20H2 is no longer compatible with saffire pro 40. There is a hack.. Firstly do what I posted before with line out etc. And check this: https://gearspace.com/board/music-compu ... mance.html
Users browsing this forum: αlphatonez and 115 guests
