I would like to use my midi controller in Studio One to operate my Reaktor Track. I managed to control my desired faders in my Reaktor ensemble using the macro rotary control, but it only works asymmetrically. As soon as I change a fader in Reaktor, nothing changes in Studio One. And what is even worse: If I adjust the macro rotary-knob and then restart Studio One, it has the value 0 again and does not remember the last setting. Is this a bug or am I doing something wrong?
That's the way a lot of controllers work. They put out midi but they get no midi sent to them.
You're wanting your hardware to reflect changes you make in the software? Maybe a look at your setup panels some might help someone see something. Need information though, like all your specs really and your hardware setup. You can put your specs in your signature, click below in my signature.
My MIDI controller (Midi Fighter Twister) receives the MIDI data from the Studio One rotary controls (for example from Pro EQ) without any problems and updates the status of my controller perfectly. The problem is not in the hardware but because Studio One obviously does not pass the Midi-Out data from the Reaktor to my MIDI controller.
You route the midi out of the Reaktor track?
Sorry, i don't understand what you mean.
I just see that any Reaktor plugin behaves different from the other plugins - not only the Reaktor instruments. For example when I load the Reaktor Chorus as an effect plugin into my tracks I can also not control the rotary controls with my midi controller. When I turn the mix-level rotary controller of the chorus, this info does not show up in Studio One and I can therefore not assign it to any knob of my MIDI-controller. |
I was just thinking that midi inside the plugin needs to get back to the controller.
Nice if you could see how the working models were setup and if you did anything different? The part that works came setup or did you set it up?
Users browsing this forum: JohHuisman and 66 guests
