Recently I discovered that when I drag an event from a track that is packed in a folder, it behaves strangely. The behavior is normal for events that are not packed in pink folders. On the other hand, events packed in blue folders show up in a distant location when dragged, making it difficult to drag and drop them to the intended location. This problem reduce my work efficiency. This has never happened before, so is this a bug? Or is there an option to fix it? I could not find it. There was a topic that dealt with a similar issue like this, but the problem seems to be unresolved. https://forums.presonus.com/viewtopic.php?f=151&t=42896&p=252266&hilit=folder+event#p252266 I am not a native English speaker, so this may be strange English. Thank you. |
Welcome to the Forum!
The folder it self lights up where ever events are inside it. So it moves when you move the events forward in time. It looks like it doesn't want to drop events to the two tracks that are named the same as the first two. I'd see if renaming has any effect. So basically looks normal except for that... Good to put your specifications in your signature, click signature below in my signature.
Thanks for the reply.
Tacman7 wroteThe folder it self lights up where ever events are inside it. So it moves when you move the events forward in time. I wasn't completely clear on this, but this happens regardless of the event or track name. I tried to downgrade to 5.02 because it was interfering with my work. Then this does not happen. I feel like this is a bug, since this behavior did not occur before. Or do you mean this is a normal behavior that has changed since 5.1? |
May be some setting I don't know about but this is the way it's always been working for me.
I have never seen that kind of folder behavior.
Maybe this is a specification that has been changed. Or something can be configured. But since it is an issue for me, I will use 5.02 for work for now and go for a support ticket when I get time. Appreciate your replies. |
tosalice wroteHi, That is a bug but I’m not entirely sure in which cases it occurs. It should not be doing that. I’m not sure if Tacman7 watched your first GIF so as to realize your second GIF is the expected behavior and the first is clearly unexpected. Does the problem also occur with new empty songs created in 5.2.0? As in, not created from a template? |
Yeah, I thought the first one was weird because he couldn't drop event on two tracks the other one looked normal.
To me...
robertgray3 wroteThat is a bug but I’m not entirely sure in which cases it occurs. It should not be doing that. Hi. Indeed, I first discovered this problem when I was using a template created with SO older than 5.2. I expected that to be the cause and created an empty project in 5.2 and created a similar folder structure, but the problem still occurred. (The first gif is from a project I created without using a template.) I need to verify this further for reporting to PreSonus, but I don't have time to do that right now due to work. |
I wasn’t able to duplicate it. Tried to set up my song the same way you show in the picture, and I even put Studio One in Japanese mode.
So either it’s limited to Windows or I’m missing some steps/settings you have on. |
I installed 5.2 again and tried it. Then I noticed a condition that causes the problem.
So far, the problem seems to occur when there is an empty folder containing an empty folder. Folder 2 in green contains empty Folders in yellow. At this time, the events in Folder 1 and the events not contained in the folder behave normally; the events in Folder 4 behave strangely, as shown at the beginning of the topic. With some manipulations, the problem will no longer occur. There may be other conditions, but for now, these are all I have found. I attach the .song file used for the gif is for verification. |
Yup, that's it. It is offset by the number of empty folders-in-folders above it minus one.
They've had to fix issues with placing tracks near other empty tracks before and it looks like this is one they must have missed. |
Users browsing this forum: Hommi and 100 guests
