Cannot delete tempo nodes
Posted: Fri Mar 26, 2021 7:48 pm
by CadErik
Some copy/pasting of sections ended up creating tempo nodes in my project and somehow, there are few nodes that I cannot select or delete... changing the global tempo ends up making a big mess... Any suggestions?
Re: Cannot delete tempo nodes
Posted: Fri Mar 26, 2021 8:34 pm
by Tacman7
Try turning snap off and see if you can select them then.
Just a thought.
Posted: Fri Mar 26, 2021 8:38 pm
by CadErik
Tacman7 wroteTry turning snap off and see if you can select them then.
Just a thought.
That did not work - the nodes were still not selectable. However by mistake I tried all the different tools and drawing a line over all the nodes did remove them. Finally cleanup my tempo track!!
Posted: Sat Aug 13, 2022 8:15 am
by mirkokatzula
OMG Thank you.. I was about to go mad!
Overwrite with the line tool helped!
Posted: Sat Aug 13, 2022 2:58 pm
by Steve Carter
Double clicking on nodes removes them in other views - not at my music computer so can’t check it in the Tempo view!
Posted: Sun Aug 14, 2022 1:34 pm
by FinalSaga
There should be two ways to remove a 'dot' on the tempo track.
You can right-click directly on the 'dot' and hit the 'remove' in that popup menu.
Second way, you can hold your left ALT while dragging a window over the ones you wish to remove and then hit the 'Delete' key
Hopefully one of these options will work for you, if not in this project (Since you fixed it) but in the future ofcourse.
Ch33rs
Saga
