Some copy/pasting of sections ended up creating tempo nodes in my project and somehow, there are few nodes that I cannot select or delete... changing the global tempo ends up making a big mess... Any suggestions?
Studio One Pro 5, Faderport 1, Console 1, MOTU UltraLitemk3 (firewire), Windows 10 Pro 64 bit
Ryzen 7 2700, 32GB RAM, Asrock mb
by Tacman7 on Fri Mar 26, 2021 8:34 pm
Try turning snap off and see if you can select them then.
Just a thought.
Win10 Ryzen 5 3600 - Motu M2
by CadErik on Fri Mar 26, 2021 8:38 pm
Tacman7 wroteTry turning snap off and see if you can select them then.
Just a thought.
That did not work - the nodes were still not selectable. However by mistake I tried all the different tools and drawing a line over all the nodes did remove them. Finally cleanup my tempo track!!
by mirkokatzula on Sat Aug 13, 2022 8:15 am
OMG Thank you.. I was about to go mad!
Overwrite with the line tool helped!
by Steve Carter on Sat Aug 13, 2022 2:58 pm
Double clicking on nodes removes them in other views - not at my music computer so can’t check it in the Tempo view!
by FinalSaga on Sun Aug 14, 2022 1:34 pm
There should be two ways to remove a 'dot' on the tempo track.
You can right-click directly on the 'dot' and hit the 'remove' in that popup menu.
Second way, you can hold your left ALT while dragging a window over the ones you wish to remove and then hit the 'Delete' key
Hopefully one of these options will work for you, if not in this project (Since you fixed it) but in the future ofcourse.
Ch33rs
Saga
Studio One v2.x 3.x 4.x-
Windows 10 Ultimate 64Bit
AMD Ryzen (3.4Ghz) and 32gigs RAM
Graphic: Radeon 5700XT
Users browsing this forum: No registered users and 65 guests
