This all started last Friday/Saturday when there was a system update for Windows 10.
I'm not sure why but every time I work on something on Studio One and then close it, it restarts on its own. I even tried closing all of the song files and then closing the app from its Start position. The same thing happens. The specs down below is slightly outdated from last I was here. I'm running version 5.2.0 EDIT: I was going to say I upgraded my rig a lot since I was last here but as it turns out, other than the version it's still pretty up to date.
Studio One 4 Professional 5.2.0 x64
Windows 10 Professional x64 Version 20H2 (OS Build 19042.867) CyberPowerPC GUA600 AMD Ryzen 5 3600 hex-core processor MSI B450 Pro Carbon AC motherboard 32GB G-Skill RAM NVIDIA GeForce GTX 1050 Ti PreSonus Studio 26C Beyerdynamic DT990 Pro Darkglass AO900 amplifier Radial Pro DI/RMP Ibanez RG9QM with one EMG 909X bridge pickup Ibanez RGA8 with EMG 808/808 Dingwall NG2 Laguna Seca Blue Kalium Custom Steel bass strings Ernie Ball Skinny Top Heavy Bottom 9-80 set single bass string (120/145) Joyo Bantamp Zombie Wacom Intuos Pro M |
It's happening to me now. I opened an older song and it closed fine. So some plugin combo?
This did happen after I made a triple split guitar fx patch with lots of inserts. Now it happens on all current songs. I am able to save, the only thing that happens is I get this after I shut down. I have to try opening and reopening more old songs and look for cause. Closed ok when I didn't save it on close, 1 time, but it can happen with no save on close.
@Tacman7
Yea, but shouldn't somebody alert the actual dev team or something about this...? o_O Having to just use a workaround like that is not only additional headache but also, if I ever need to open up an old song file it ends up saving as if it were current gen and that happens again so... Also, as a side note, there's nothing complex about what I'm doing FX chain wise.
It's restarting the application but it just gets to that splash screen so you can click quit.
You get that screen when you start S1 also. I think it's going to get plenty of attention. It could just as easily be a win10 problem/interaction. Is this happening to any mac users?
This is a serious problem that can crash the computer though.
That said, I'll have to take this to Support although I don't know if it'll even do much.
I made some inquiries but I'm not really able to pin it down, they will but they need data.
I still have it happen most times but not all times. Haven't heard from any mac users though...
dlrange wroteevery time I open Uad dream verb it crashes Ive been back and forth with tech and no answer or solution I have never had this many crashes or issues You know the plugin that causes this, so create a new thread and list your specs in your signature, and your issue can be discussed. The more detail the better.
Welcome to the Forum dlrange!
Good to put your specs in your signature, click below in my signature. So you opened a ticket with UA? Need more info... And yes good to start your own thread, Thank you AI!
o it has taken me a while to figure this out even sweetwater we couldn't figure it out my focals were popping with kick drum and basss. studio one 5 crashing a lot sound quality wasn't good either compared to luna or logic
so I uninstalled everything restarted same problems but its with old songs had dream verb was crashing etc so yesterday I did 2 brand new songs from scratch after reinstalling studio one and cleaning. no problems so anyone having problems try this and don't open any old or saved songs Im wondering is there a glitch with old songs and the updates everything is running fine as long as I don't open any previous material Ive did like six new songs and no problems but once u open and old file it causes an issue |
Yea it was a strange thing after a win 10 update several people were having problems.
It would come and go for me but after trying a lot of things it just seems to have gone away. I boot up S1 clean and it closes without a crash screen even on the songs that were causing problems before. Still need some info about your setup dlrange. If your symptoms are different you should start a new topic.
dlrange wroteo it has taken me a while to figure this out even sweetwater we couldn't figure it out my focals were popping with kick drum and basss. studio one 5 crashing a lot sound quality wasn't good either compared to luna or logic If old projects aren't working and new projects are it certainly isn't windows libraries via windows update. Try creating a new project and cutting/pasting/importing in tracks from an old project. That might do some cleanup. Also try.updatong your plugin if you can. Otherwise new thread please.
Users browsing this forum: No registered users and 73 guests
