A real head-scratcher: I created a multi-instrument with both the condenser and ribbon mic versions of the Presonus Studio Grand Piano. I set a MIDI input channel and recorded a part on said channel, no issues, I hear the instrument in real time and recorded data shows in the arranger and edit windows. Here's the strange part: on playback, all I hear are the sustain pedal samples. The note data sounds when I click on events in the edit window, but not on playback, just sustain pedal.
I can make complete playback work by setting the Direct Input on the multi-instrument to "None", but the only thing that sounds on playback when input is set to my controller or "All Inputs" are the sustain pedal samples. Other single instruments work fine, but factory multis - same problem. Is this a feature? Or a bug? I know I can just switch inputs as I go, but it's an annoying hiccup in the work flow. |
Users browsing this forum: sebastianholtzer and 24 guests
