First off, I'm confused about the dither setting in S1. It adds dither on playback and export? It's my understanding that dither should only happen once, as the last thing in your chain when converting from one sample rate to another and exporting. I'm not sure why you would want dither on playback? That being the case, the dither option should appear directly in the various export menus, not buried in a settings page, IMHO.
Also, from admittedly limited testing so far, I'm not finding the S1 dithering algorithm to be very smooth sounding. To me, it does not sound as good as the dithering in the Waves L-2. I'm curious how others are dealing with dither and if anyone is using the S1 dither. |
The reason one may like dithering while playback is that internally Studio One audio engine is operating at 64-bit floating point while most interfaces operate at 24-bit. So you're always bit reducing when playing back.
I personally keep the option off and prefer to use a dither from a limiter at the end of my project page chain. Always remember its good to use dither, but no great song was ever made un-listen-able by forgetting to apply it.
Toronto, Canada
Windows 10 (2004) 64-bit, Ryzen 3900x, 32GB RAM, GTX 960, 4K + Triple Touchscreens Presonus 192, Steinberg Midex 8, Faderport v2, Atom SQ, Akai Advance 49, Keystation 61 mk3, 2x Behringer X-Touch Mini, Arturia: Keystep, Microfreak; Behringer: Model D, Neutron; Yamaha: FB01, CS; Korg: Minilogue, Microkorg, MS20; Novation: A-Station; Roland: JP08, D-110; AudioThing P6; 800HP Eurorack |
Thanks for the reply.
That seems to be the way to go, as far as I can tell. I came from Cakewalk/Sonar and it had the Weiss Pow-r dithering algorithms, which are great. I was hopeful that I could just use S1's native dither but, I experimented with it compared to what's available in my Waves L2 and, I hear a noticeable difference between them (The Waves sounds better, smoother in the high end.) Hopefully in a future update Presonus might switch to a better dithering utility. |
This is the only thing I put on the master:
https://www.soundonsound.com/reviews/psp-xenon I will have to try turning off dithering and let the plugin do it and compare.
Please add your specs to your SIGNATURE. Search the STUDIO ONE 5 ONLINE MANUAL. Access your MY.PRESONUS account. OVERVIEW of how to get your issue fixed or the steps to create a SUPPORT TICKET. Needs to include: 1) One Sentence Description 2) Expected Results 3) Actual Results 4) Steps to Reproduce. Studio OnePro5 Melodyne Studio Studio Computer - Nectar Impact LX25+ Win10 i7 7700k 16gb ram 1TB SSD AsusH270M-PLUS interface:StudioKonnekt 48 Kitchen Computer - Microkey Air Win10 Ryzen 5 3600 - Radeon RX 590 - 16GB DDR4 3000MHz - 512GB SSD interface: Motu M2 |
rodshort wroteThanks for the reply. L2's limiting has a classic sound. its the sound of 2000s pop music. But dither either does its job or doesn't - there is no "quality", Perhaps its the noise shaping Presonus is using that you don't like. Here is a timeless video about sampling, theres a portion on dither. https://xiph.org/video/vid2.shtml
Toronto, Canada
rodshort wroteFirst off, I'm confused about the dither setting in S1. It adds dither on playback and export? It's my understanding that dither should only happen once, as the last thing in your chain when converting from one sample rate to another and exporting. I'm not sure why you would want dither on playback?. Then consider this: If you listen without dither but export with dither then you'll be exporting something you haven't actually heard. Dither on playback is fleeting; it isn't printed or re-used unless you use outboard hardware inserts (which may be another reason to have the dither-on-playback option). So I understand the default=on setting. That way you'll hear what the final product sounds like ![]() |
mycbeats - You may be right, a noise shaping algorithm may be the difference I'm hearing. I know it's a small difference but, I do hear a difference in the high end.
Users browsing this forum: No registered users and 30 guests
