Hi
I recorded at 48khz 24bit a vocal over a backing track. I sent the whole project to my engineer so he can build a new backing track from Vst instrument. He said when he did this all seem to go ok until it came to export Mixdown, this is when the "sample rate does not match hardware settings" came up. He noticed at bottom left or UI it says 96khz 32bit. He goes into that setting and it shows 48khz, then it seemed to change it by doing nothing? He tried changing hardware settings, setting for song,but it either changed the pitch of the vst instruments or sped it up. He was using a Propellerhead Ballance hardware. He tried his older focusrite USB 5 interface but that gave constant crashes windows 10 related. On my laptop with no special sound card the track loads fine but wont play back, no track plays back on my laptop sound, but it does via my Soundblaster play USB sound. He said he also noticed no lag while playing vst but notes where all behind. Thanks for any info. |
Users browsing this forum: No registered users and 28 guests
