21 postsPage 1 of 2
1, 2
So, my Zoom UAC-2 works with every other audio application I have including Studio One 3 and FL Studio but it just absolutely will not talk to Studio One 5.
Am I the only one with this problem or is it something specific to the hardware itself?
by Trucky on Fri Dec 18, 2020 8:07 pm
What Operating System are you running?
Have you contacted Zoom support regarding this issue?
https://zoomcorp.com/en/us/contact/
Download the SO 6 PDF MANUAL. Access your MY.PRESONUS account.
Needs to include: 1) Subject 2) Description 3) Country 4) Product 5) OS 6) Audio Software
Windows 11 Pro 64-bit (23H2), Studio One 6.6 Professional | Notion 6.8.2 | Universal Control v4.2.0.96206
Intel NUC 13 (Intel i5-1340P, Intel Iris Xe Graphics, 32GB RAM, 2TB SSD, Revelator, SIII 32
by badsearcher on Sat Dec 19, 2020 6:40 am
No, but I expect that if I tell them that their hardware and drivers work perfectly with Studio One 3, FL Studio, my standalone VSTs, and all of my games and other apps that use audio, they're going to deduce that the problem is Studio One 5, not with the UAC-2.
by shanabit on Sat Dec 19, 2020 8:11 am
I would reinstall version 5 if I had that issue. It has to be one of two things
1. The driver does not work with S1 5
2. The installation of S1 5 has an error
**The assumption is you have configured the audio device from the start page
StudioOnePro 6.1
UA Apollo Twin
OSX Sonoma 14.2
iMac 2013
by badsearcher on Sat Dec 19, 2020 5:42 pm
I've reinstalled studio one 5 multiple times, I even deleted the Presonus folder from appdata/roaming before a reinstall in order to get an extra clean reinstall.
It just won't budge.
But am I totally alone in the wilderness, is anyone with a UAC-2 have Studio One 5 working?
by shanabit on Sat Dec 19, 2020 8:30 pm
Do you have the Class Compliant switched on on the back or are you using a dedicated audio driver for it?
Latest firmware for it?
Latest drivers are back in Feb BTW, Im guessing if your other DAWS are working and your able to get sound with online stuff etc its S1 causing the issue here.
https://zoomcorp.com/en/us/audio-interf ... 2-support/
**When you go to Configure Audio Device from the start page you are saying it is NOT showing up there correct?
Try DELETING the S1 5 Preferences File as well
Very easily could be a conflict with the Windows version and S1 5
StudioOnePro 6.1
UA Apollo Twin
OSX Sonoma 14.2
iMac 2013
by badsearcher on Mon Dec 21, 2020 4:21 pm
Class Compliant Mode is off.
I have the latest firmware.
Just to be clear, it IS showing up in the start page, just the transport doesn't move and it doesn't output or record any sound under any circumstances.
I've deleted the preferences file multiple times as well.
Nothing I can do seems to work.
But, I ask again, is it just me, or has anyone else actually managed to have gotten a ZOOM UAC-2 to work with Studio One 5?
by Trucky on Tue Dec 22, 2020 11:12 am
badsearcher wroteNothing I can do seems to work.
Due to lack of responses here from other Zoom UAC-2 owners, I'd still recommend contacting Zoom technical support.
They probably have more details if this issue has been reported by other Studio One 5 customers.
by juhaseppnen on Sun Jan 10, 2021 11:11 am
Hey, did you get it working? I was planning to buy the Zoom, the bigger version though.
Studio One Pro 5.5.2.86528
Windows 10 - 8700k - 16 GB - MSI Z370 Sli Plus
Arturia Keylab 88
Presonus Studio 1824c
by pwheeler on Sun Jan 10, 2021 5:04 pm
I have a Zoom UAC-2. Works fine for me with Studio One 5. No problems at all using the latest Zoom ASIO drivers.
http://wheelermedia.net/
StudioOne v5 latest release - custom built PC, Win10, i7 9700k, Gigabyte Z390 UD, 16GB RAM, a few SSDs, Zoom UAC-2, Mackie HR824 monitors + loads of plugins.
Selmer Reference 54 tenor sax, Selmer SA80 Series III soprano sax, Akai EWI 4000s and a Korg SV1
:thumbup:
by badsearcher on Sun Jan 10, 2021 5:09 pm
Oh, that's interesting, good to know that it works, still that means it's impossible for me to figure out what could be the problem. Oh well.
by pwheeler on Sun Jan 10, 2021 6:08 pm
If it helps, I run it at 24 bit and 88khz.
If I recall the Zoom doesn't like switching modes, so check you are running the same bit depth and sample rate as the other DAWs.
Otherwise, maybe a conflict having S1v3 and v5 together on the same PC perhaps?
Oh and I'm running Windows 10 latest release. if you're using a Mac, maybe an issue with the latest MacOS?
:thumbup:
by Trucky on Tue Jan 12, 2021 8:11 pm
pwheeler wroteI have a Zoom UAC-2. Works fine for me with Studio One 5. No problems at all using the latest Zoom ASIO drivers.
Thanks for confirming that it works with Studio One 5 and Windows 10 with the latest Zoom ASIO drivers.
by badsearcher on Sun Mar 21, 2021 10:53 am
Apparently I'm not alone in these problems,
https://answers.presonus.com/62246/zoom ... -with-s1-5
this was posted six days after and it's someone with a Zoom UAC-8 (the 8 channel version of the UAC-2) having the same exact problems as me.
So, if someone was able to make a ZOOM UAC work, then that's a good thing, it means somehow some way there's a solution but my experience and this unanswered question means there is a recurring issue among ZOOM UAC users, it's not just me.
Edit: I tried switching it to 88.2 khz and 24 bit but that didn't change anything either.
by Trucky on Mon Mar 22, 2021 1:28 pm
What OS are you running?
What did ZOOM support say?
by badsearcher on Mon Mar 22, 2021 8:29 pm
I'm running windows 10, latest update. I'm still waiting for Zoom support to respond. If other people also have had this exact problem then maybe Zoom can help.
by badsearcher on Thu Mar 25, 2021 10:00 am
"Hello,
Zoom products are not confirmed to be compatible with Presonus Studio One 5.
We apologize for any inconvenience."
Hmmm, oh well, maybe there'll be a driver update, I guess I'll keep trucking with Studio One 3 in the meantime until a driver update comes out or maybe I'll consider another audio interface. I bought the Zoom as a budget friendly low latency option 3 years ago but maybe I'll look at what else is out there since then.
by Trucky on Thu Mar 25, 2021 11:43 am
Thanks for confirming Zoom Support's response to you here.
by AtomOne on Sun Oct 17, 2021 2:47 pm
same here UAC-8 will not play with Studio5
by markrobotham on Mon Oct 18, 2021 8:48 am
AtomOne wrotesame here UAC-8 will not play with Studio5
I have a UAC-8 and it works fine with Studio One 5.4.1 The UAC-8 uses USB 3.0 so you might want to make sure its not plugged into a USB 2 port.
    Windows 10 Enterprise 21H1
    ASUS TUF B450-PRO GAMING
    ASUS VP28U 4K Monitor
    AMD Ryzen 9 5900X 12 Core
    64GB DDR4 3200MHZ
    MSI GeForce RTX 3060 GAMING X 12G
    Zoom UAC-8 Audio Interface
    Studio One 6 Pro (Latest Version)
    Notion 6 (Latest Version)
    Sonar Platinum x64 Lifetime
[ YouTube ] [ Omnisphere Libraries ]
21 postsPage 1 of 2
1, 2
Users browsing this forum: leosutherland and 76 guests
