Hope someone can help me please! For some reason I can no longer trigger instruments from my Akai LPK25 keyboard anymore. The indicator at top right of instrument is yellow and shows the LPK25; the midi monitor is showing notes on and the VI plays if I use my onscreen keyboard etc. But I can't play from my AKAI (works on Reaper etc just not on S1) Please help if you can, TYI
Last edited by stephanforster on Wed Oct 21, 2020 12:18 pm, edited 1 time in total.
MacBook Pro 2019 16gb ram running Catalina. Focusrite Scarlet 18i8 interface. Akai LPK25 midi keyboard and Akai LPD8 drum pads. Presonus Studio One v 5.1
by cristofe on Wed Oct 21, 2020 11:29 am
Well, if your Akai works in Reaper no problem, you've already eliminated it as the problem. Sounds like an improper setting in S1. Maybe you accidentally changed some setting? Anyways, here's a good tutorial that may be of some help:
https://www.youtube.com/watch?v=Wi2Kj8MX7_c
That being said we can help you better now and in the future with a bit more info......if you will post your system specs in your signature, (see my sig), we will be better able to troubleshoot your problems. Without knowing what type of pc you're running, what OS you're using, make and model of your audio interface etc....we often can't recommend a "simple fix"
by stephanforster on Wed Oct 21, 2020 12:16 pm
Thanks for your reply- I have watched the video and read the manual but still no joy, although the MIDI monitor shows incoming activity when I play the keyboard but still doesn't "play" the Virtual Instrument (even though the keyboard is selected in yellow on the focus device). As you said, it seems that another setting has changed though for the life of me I can't see what?
Hope you have some more ideas please?
BTW I updated my profile as well
by Bbd on Wed Oct 21, 2020 12:25 pm
I would contact Support about this. It may not be a complicated fix.
by stephanforster on Wed Oct 21, 2020 12:32 pm
Thanks will contact them
by Jemusic on Wed Oct 21, 2020 2:26 pm
When you create an Instrument track, what is the setting for the Input source. Check to see that it is still your controller. (Or ALL INPUTS)
Are you input monitoring. You wont hear anything until you do.
Specs i5-2500K 3.5 Ghz-8 Gb RAM-Win 7 64 bit - ATI Radeon HD6900 Series - RME HDSP9632 - Midex 8 Midi interface - Faderport 2/8 - Atom Pad- iMac 2.5Ghz Core i5 - High Sierra 10.13.6 - Focusrite Clarett 2 Pre & Scarlett 18i20. Studio One V5.1 (Mac), Notion 6.7, Ableton Live 10 Suite, LaunchPad Pro
Users browsing this forum: georgegidzinski, georgenext and 54 guests
