Studio One 5.1 is online
Posted: Tue Oct 20, 2020 9:17 am
Dearest community,
here's Studio One 5.1.0 (build 61423).
Release Notes
New features and improvements:
Recording and Mixing
The following issues have been fixed:
Enjoy!
Release Notes
- Retrospective Recording
- Track/Channel search and filter options
- Bypass option for Gain Envelopes
- Drag & drop send chains
- Improved presentation of Global Tracks
- Secondary Timeline Ruler option
- New combined Signature Track (time and key signature changes)
- Transfer key signature events using ARA
- Global Tracks in Editors (Marker, Arranger, Chords, Signature)
- Score Printing
- Score View: Key Signature Changes
- Score View: Staff Presets
- Score View: Staff Settings
- Score View: Alternative views
- Score View: Noteheads selection
- [Impact XT] Colorized events in Pattern Editor
- Edit indicator for Patches
- External instrument support for Patches
- [Ampire and Pedalboard] New Compressor and Gate FX pedals
- Drag & Drop FX pedals between Ampire and Pedalboard
- [Start Page] Search function for songs, projects, and shows
- [Project Page] Digital Release never adds a 2-second pause
- 4 Banks of assignable Encoders
- 4 Banks of assignable Pad Commands
- Scales in keyboard mode
- Open Note FX editor option
- Replace instrument option
- Alternative views for Instrument Rack
- [macOS] Switchable hardware graphics acceleration
- [Windows] High-DPI scaling option re-enabled
- [Windows] Improved user experience with consumer-grade non-ASIO audio devices
- [Windows] flickering play cursor at 175% scaling
- [Windows] Irregular grid lines at 125%, 150% and 175% scaling
- [macOS] Note event vs. audio timing off grid at high buffer settings
- [macOS HiSierra] When pinning Soothe 2, all other plug-in windows are stalled
- [macOS] Graphical performance degrades when scrolling collapsed folder
- [macOS] No redrawing of icons when switching resolution
- [macOS] Text not clipped in browser tile
- [macOS] Unwanted wrapping in certain text boxes
- [macOS] Laggy graphics with certain 3rd party plug-ins
- [Browser] Can't delete certain custom folders
- [Browser] Crash on expanding certain track folders
- [Browser] Selecting multiple items in Tree View doesn't work on first click w/ Shift
- [Mixer] Monitoring live input from bus no longer possible
- [Mixer] Multi Instrument primary/master channel name is not retained
- [Mixer] Pipeline XT not passing audio when inserted to Listen Bus
- [Mixer] Solo safe in aux channels forces realtime render when bouncing a virtual instrument track
- [Mixer] Keyboard shortcut "add gain trim" always opens 1st insert slot
- [Presence XT Editor] Decimal shift when entering tune values
- [Presence XT Editor] Wrong conversion when entering negative 'Tune' values
- [AutoFilter] Leftover TODO tooltip
- [Impact XT] Sample offset settings are not recalled
- [Exchange] .ioconfig "installs" to default "Download" folder
- [Note FX] Arpeggiator chokes up in certain situations
- Audio miscalculation on extreme tempo edits
- Audition is suspended too early on recording with Auto Punch
- Automation may migrate to a different track
- Can't create audio track above a folder track via drag and drop
- Can't duplicate a transformed Instrument Track
- Certain original audio cannot be dragged into arrangement
- Delay compensation / latency not updated unless the plugin is reset manually
- Duplicating automation sometimes not working properly
- Event text position is odd on high vertical zoom levels
- Export mixdown is longer than loop range when an AUX channel is present
- Graphic ghost and font space issue when event badges are disabled
- In Step Recording mode, cursor does not advance after input notes when the Tempo Track contains nodes
- Last track in the Arrangement cannot be resized if it has been minimized
- Listen bus metering options are following audio track metering options
- Misc 3rd party plug-in window resize issues (Kilohearts, Melda Productions, Waves...)
- Noise when loading a song w/ Ampire when Dropout Protection is set to Maximum
- Open folder range selection disappears on copy/paste command
- Potential crash when editing audio bend markers
- Second external device plugged-in is not auto-detected sometimes
- Context menu reacts differently to mouse clicks on macOS and Windows
- "Stop at Marker" is being ignored in certain situations
- Unwanted behavior when copying sections w/ enclosed automation
- Updating an Instrument+FX Preset creates .preset file instead of .instrument
Enjoy!
