Hi All
I just bought Generate from Pluginboutique because it was 33% discount - having already got the free Pendulate VST to see what it was all about.
Generate is activated via iLok. Both pendulate.vst3 and generate.vst3 are sitting in the usual place:
Program Files\Common Files\VST3\Newfangled Audio
S1 v4.6.2 has that location set (although I hadn't actually set it when I got Pendulate, which worked fine). Anyway, the problem is that while Pendulate is listed in and usable from the browser, Generate is not. :roll:
I know the above location is correct because if I rename pendulate.vst3, the test song that uses it complains it can't find it - it is therefore not anywhere else on my system.
I've tried the clearing blacklist, resetting/setting location, rebooting machine, refreshing the Instrument browser tree, etc - Generate just isn't appearing in S1 :?
...said Halo
Studio One Pro v4.6.2
Serum, Diva, Repro, Synthmaster, Massive, Syntronik Bully, MTron Pro, Kontakt/Reaktor, Xpand!2+AIEP3, PPG Wave 3.V, KLC, Generate, Battery 4, CA2600
Reference 4, Reverberate Core
3XS SQ170 Music Studio PC
Windows 10 x64 (1903)
i7 8700 Hexcore 3.2GHz, 16GB DDR4-2666, 1TB 970 EVO M.2 NVMe SSD + 1TB SATA HD
Scarlett 2i4 (G2), Korg Taktile 25, Faderport 2018, ATOM
MSI GE62VR 7RF Apache Pro
Intel Core i7 7700HQ 2.8GHz, 16GB, 500GB 970 EVO M.2 NVMe SSD + 1TB 860 SATA III SSD
Beyerdynamic DT990 Pros, JBL 305P II speakers
by Jemusic on Mon Oct 19, 2020 1:22 am
Have you clicked on the little wrench icon to make sure they are are not invisible.
by leosutherland on Mon Oct 19, 2020 2:45 am
Jemusic wroteHave you clicked on the little wrench icon to make sure they are are not invisible.
Hi Jeff
I think at some stage I did (when I was clicking things at random), but I certainly wouldn't swear to it. Will try that tonite and report back.
BTW did you get Generate yourself in the end?
...said Halo
by Jemusic on Mon Oct 19, 2020 3:16 am
Not yet but I do like Pendulate though. Its very interesting and it has quite a robust sound to it. Generate must be cool being polyphonic and all.
Check that that your iLok is all OK too with Generate. I have found if something is not actually registered properly with iLok it just wont show up at all in Studio One either.
Also worthy of note is Groove 3 have a free course on Pendulate.
by Baphometrix on Mon Oct 19, 2020 9:12 pm
I have Generate and it's working fine in S1.
Studio One 5.1 Pro (Sphere) | Bitwig 3.2.x | Ableton 10.x
Faderport 8 | ATOM SQ | MOTU M4 | Push 2 (Shove)
Windows 10 Home | i9 9900K | 64 GB RAM | Geforce RTX 2070
by leosutherland on Tue Oct 20, 2020 6:41 am
shannongreywalker wroteI have Generate and it's working fine in S1.
Hi Shannnon
If you go into the iLok manager, and look at the details for your Generate licence, is there an activation code listed? For mine, I have the SN and the Key, but not an activation code - I don't know if I'm supposed to have and activation code to redeem or not. The iLok manager is reporting my Generate is activated OK (1 of 2), however.
I got Serum and Xpand!2 activated via iLok, and those licences do have a code listed, and they work absolutely fine.
Perhaps lack of that code is what is preventing S1 from seeing the Generate VST?
...said Halo
by Baphometrix on Tue Oct 20, 2020 12:42 pm
Hi Shannnon
The "Activation Code" field is blank for me. I think you're down to contacting support at the Eventide site to figure out what's wrong?
by Baphometrix on Tue Oct 20, 2020 12:45 pm
Just on a hunch.... You ARE seeing "1 of 2 activations used" in the row for Generate (in iLOK Manager), right?
by Jemusic on Tue Oct 20, 2020 7:10 pm
I had some issues getting some AIR plugins to install, activate properly in iLok and show up in Studio One. I also got a message at some point saying that I had run out of activations as well.
You need to contact the people that you bought it from, ie PlugInBoutique. (not the actual makers of the plugin either) In my case it was PlugInBoutique as well and they were very helpful.
by leosutherland on Wed Oct 21, 2020 3:56 am
Thanks for all your help, guys. :thumbup:
Happy to report all is solved now - and nothing to do with iLok (a blessing in disguise) :D
It appears that Generate doesn't work when it is in
but it does work fine in
Whereas Pendulate works fine in either location, however - lack of consistency there, methinks :?
Because of some posts in the forum about similar problems, I earlier also tried it, but unsuccessfully, in
Program Files\VstPlugins
Of course, my next problem is to suss out how I can use Generate (and Pendulate, might as well continue to use that as well) ;)
...said Halo
by Jemusic on Wed Oct 21, 2020 5:16 am
Glad you got it going.
If you have a Groove 3 account it is well worth watching the free Pendulate course. I have learned a lot already and not even finished it yet.
by Baphometrix on Wed Oct 21, 2020 5:49 am
leosutherland wrote...It appears that Generate doesn't work when it is in
It works in the default location for me. Regardless, glad you managed to shake the vending machine and finally got it to drop that candy bar. :+1
Generate is great. Pretty much all of Dan Gillespie's stuff is interesting and good.
Users browsing this forum: bruceqld, lhansen and 47 guests
