Hello,
I just recorded a guitar audio track but sadly can't hear anything when playing back the recording. Probably some settings are incorrect. I'm sending screenshots of the song setting along. sorry for a total newbie question. I hope this will be easy to answer for all of you and thanks in advance for your help.
Best, Tido
Sorry, it' the German version, but I hope you understand
by Tacman7 on Sun Oct 18, 2020 10:44 am
Welcome to the Forum!
I would need to see how your tracks are setup maybe. Your specs would also be good and your interface.
The input panel looks like nothing is selected. See how your output looks or this panel:
Studio OnePro5.1 64bit Melodyne Studio
Studio Computer - Nectar Impact LX25+
Win10 i7 7700k 16gb ram 1TB SSD AsusH270M-PLUS interface:StudioKonnekt 48
Kitchen Computer
Win10 Ryzen 5 3600 - Radeon RX 590 - 16GB DDR4 3000MHz - 512GB SSD interface: Motu M2
by tidovonwedel on Sun Oct 18, 2020 10:51 am
Hi Tacman7,
thanks for your quick reply. I really appreciate it :-) As to my specs, I'm using A Macbook pro with Studio One 5.0.0.59360 (current version). My interface is a Presonus AudioBox USB96.
by tidovonwedel on Sun Oct 18, 2020 11:14 am
Meanwhile I can hear the recorded track. I connected my headphones to the Mac instead of the AudioBox. What is better? The next problem I have is that I can hear the sounds of the first track on the one I recorded, what is annoying. How can I get a clean treordeing of the guitar?
by Tacman7 on Sun Oct 18, 2020 11:32 am
You want to use your interface.
Like I say, I can't see where input 1 and input 2 are assigned and where the track uses that input for its input setting.
https://s1manual.presonus.com/Content/S ... Device.htm
https://s1manual.presonus.com/Content/S ... Output.htm
https://s1manual.presonus.com/Content/R ... Tracks.htm
Kitchen Computer
by Lokeyfly on Tue Oct 20, 2020 5:17 am
Like Tacman stated, there's not enough to go on to solve your question. However, you may want to verify a few simple things along the way.
First, when you record a track either by headphones through your Mac, or interface (preferably interface), make sure your track is record ready, and monitor ON when recording. Also verify as you record, that you see the waveform being generated on the track. That will ensure there is a print (recording) taking place on the track. If you have no print shown, even now with the track you're enquiring about, then you never actually recorded it.
Hope that helps. ;)
S1 Pro 4.6.x, Laptop: VAIO i7, 8 core, Win 7 64x. Audio Interface: Audiobox 22 VSL, Audiophile 192 Controllers: Arturia Keylab 49 MkII, Novation SL25 MKII, Faderport 8, Roland JV-90, Roland GR-50, Roland Octapad, Akai MPD-18. MIDI Patchbay: MOTU 8x8, Monitoring: Mackie HR824, Yamaha HS-7, Mixer: Yamaha Promix 01, Rane HC-6.
Latest albums on iTunes
LP's "Amber & Blue", and "Reasonable Approach" available on all major distribution music services.
Simply search "James Conrad Tucker".
All songs copyright. Be safe.
by tidovonwedel on Sun Oct 25, 2020 11:04 am
Hi Tacman7 and Lokeyfly,
I'm still having trouble to set up Studio One properly to record my guitar. I've connected the headphones to my AudioBox (and could hear sound before but not now).
As you can see on the attachment I've clicked on the input channel and it turns blue however if I go back to check it turns to black, so I'm not sure whether this is set correctly. It seems I can not save this setting. On the song view I click on record and the button turns red (see attachment). Also I selected the Input from the trop down menu on the left. Sadly I can hear no sound and also nothing is printed on the track. What should I do to fix this?
Thanks again. Best, Tido
Users browsing this forum: bruceqld, lhansen and 33 guests
