Hey guys, I want to be able to toggle between 2 different songs during live play via midi trigger. How is this done ? Thanks !
by Tacman7 on Tue Oct 13, 2020 7:57 am
There's a key command that is Switch to Song that will take you from project or start page to a song but couldn't see what would change a song. I tried it, didn't work.
Macro is probably the way to go.
Studio OnePro5.1 64bit Melodyne Studio
Kitchen Computer
Win10 Ryzen 5 3600 - Radeon RX 590 - 16GB DDR4 3000MHz - 512GB SSD interface: Motu M2
by stevenessel on Tue Oct 13, 2020 9:05 am
Thanks for the reply, So what I am trying to do is, I play edrums live and I trigger a drum VST and would like to switch between 2 different drum VST's via a dedicated drum pad during live play. The only way I see to do this was to open a song with 1 Drum VST loaded and then open another song with the other drum VST loaded. If there is another way you think would be the best way to accomplish this ?
by Tacman7 on Tue Oct 13, 2020 9:17 am
Have two tracks with different VSTi's on them and you monitor or solo that track.
I think you could use control link to control the monitor buttons or whatever way you wanted to do it.
https://s1manual.presonus.com/Content/C ... l_Link.htm
Kitchen Computer
by stevenessel on Tue Oct 13, 2020 9:58 am
I would need to do this action with one hit of a pad, But there are many actions needed to happen within that one hit. For example, There will be 2 tracks with a VST on each and they both would need to be armed some way or muted with just one hit of a pad.
by Tacman7 on Tue Oct 13, 2020 8:02 pm
Well if each track had a pad assigned to the mute button then you could mute or unmute them as needed.
I'm not sure if you can assign two controls to one hardware pad, If you can then might be able to do what you want.
Kitchen Computer
Users browsing this forum: bruceqld, lhansen, Tacman7 and 40 guests
