williamhajjar wrote Contact UA Support : https://help.uaudio.com/hc/en-us
I also cannot work because of sounds cuts. You should be aware of this latency issue on plugins. latency is broken in 5.0. even if I just open the browser, I will get this problem. There are a lot of scenarios in which the problem appears. Have a conscience. you have to fix the studio one we pay money for it. This is not only my problem, we tested it on 15 different PCs of different people. It's doedn't workble now.
Some really good advice: viewtopic.php?p=245053#p245053
I had a problem with the Studio 192 interface. I didn't post about it, I opened a ticket. I went back and forth multiple times with support because they were unable to reproduce it, until I eventually provided a clue that allowed PreSonus to reproduce the issue and isolate the problem. Two weeks later there was a firmware update, and the problem was solved.
Digital storefront: craiganderton.com
Free educational site: craiganderton.org Music: youtube.com/thecraiganderton Studio One eBooks: shop.presonus.com |
williamhajjar wrotePreAl wrotewilliamhajjar wrote I cant go back because all my projects have been opened on studio one 5 and cant work on 4. Actually... open up an older version of studio one and start opening up auto saved versions of these projects... the most recent ones will probably not work because they’ll be version 5, but, soon enough, you should find one done in v4.xx and it’ll open fine Further: I literally have no symphony any longer for anyone who updates their daw blindly when the update tells them upfront that saving under the new version will make that file unusable in prior versions of the daw... it’s 2020 for God’s sakes... if you’re a pro, you know how this works already and would never do something so foolish... if you’re just a hobbyist? Again, that warning window is there for a reason. Just because you blindly click through it doesn’t release you from responsibility of your own recklessness. Keep the old version installed... keep current copies of projects saved under that version. If you feel the need to open these sessions with the new version, do it! I do all of the time... but, as soon as open it, click SAVE AS, give it a unique name and now you’ll have a new version of the project.. so, you’ll be protected. I know, I’m the a-hole
https://soundcloud.com/brotherbrim/sets ... ernational
win 11 pro... S1 pro latest version... 64 bits... Rme latest drivers... All the ram and i9 3900k monster... |
All you have to do after opening a V4 song file in V5, is do a SAVE AS and simply add 'V5' at the end of the song title. Then you have got both.
spectacular g wroteAnyone here capable of getting a support ticket dealt with? I've been locked out of my sphere acct since Sept 5th and my ticket has yet to be replied to. Can you still access mypresonus or does it try to forward to sphere page? https://my.presonus.com/support/open |
leonseaman wrotespectacular g wroteAnyone here capable of getting a support ticket dealt with? I've been locked out of my sphere acct since Sept 5th and my ticket has yet to be replied to. Sphere menu navigation is a nightmare: https://sphere.presonus.com/home Once you are in click the globe icon at the top of the page, in the middle of a menu (a hidden "Easter egg" ) which will display the support button. Or do what I do, avoid the menu navigation spaghetti altogether (sorry Presonus but your website portals are an absolute rodent maze, and gives off an image from the 1990s, much like how these forums look!) and just go to their support portal. https://support.presonus.com/home - submit a request top right hand corner. If you don't see it, sign in and try the link again If you already created a ticket check that it hasn't been closed. Btw we only just discussed this, troubleshooting should be on its own seperate thread and not here.
williamhajjar wroteLast post here because of the "hijacking". You are not alone. Console 1 has ongoing issues with Studio One. Just when I find a suitable workaround it fails and I have to find another. I just received a response from softube support claiming no one else has reported anything. My issue will usually result in the GUI being corrupted and the only functionality is with the input and output meters. It will even cause my whole system to lag. Sometimes Studio One auto save will run endlessly
Mac Mini (Late 2014)
frank.crow wroteI just received a response from softube support claiming no one else has reported anything. I find that surprising. When I was considering purchasing it, I searched for “Console 1” on a few Facebook groups and Forums and was blown away how many people were reporting issues with integration in various DAWs. Since that’s the selling point of the whole thing, I declined to invest in their system. |
robertgray3 wrotefrank.crow wroteI just received a response from softube support claiming no one else has reported anything. I was surprised by the techs comment too. It’s actually pretty amazing when it works but I have had to Progressively cut aspects of my workflow to accommodate the returning glitches.
aduki wroteI was thinking of getting a Console 1 Mk2. I told the tech about these complaints and he asked for the website. I explained it was a customer only forum and one had to have a Presonus product registered. Too bad because he really seemed oblivious to all of these complaints. Probably thought I was exaggerating.
Users browsing this forum: No registered users and 50 guests
