I have been getting the issue where automation does not work during the mixdown (the mixdown dialog window freezes). I know this was a problem, or maybe still is a problem of Studio One. Has this been fixed, and if so, what version was it fixed in? I'm currently running 4.1.1.
My specific problem is that I'm muting buses and automating those buses. It seems to not be a problem for the actual tracks. Thank you. Zach
So if you mute and unmute the bus using automation
you won't make it through an export mixdown but if you disable that automation then you can? Good to put your specs in your signature, might be useful info, click the word signature below:
4.6.2 is the final 4.x version of Studio One, You should update to this regardless..
Version 5 is now out.
I've updated my signature.
The mixdown will still happen, but those busses that were muted/unmuted via automation will not properly be incorporated. Sometimes they will mute and not unmute. Sometimes vice versa. Sometimes they work fine. Sometimes nothing automates. It depends on the buss to exactly what happens, but it is consistent everytime. |
Yup - posted recently with similar occurrences (v4.6..latest) with automation and tracks dropping out towards end of mixdown. Didn’t manage to solicit any solutions and I’m guessing that the developers are unlikely to be concerned as their focus is now v5....
Hoping for a Black Friday offer for the upgrade ‘cos we’re in lockdown again here in France and I’m self employed so gotta be careful with expenditure - keep safe out there!
Hello,
I have the same problem. When exporting and using automation the automation is not being rendered after 1:20. This happens every time and is very vexing. I'm using S1 version 5.1.1.61815 and I have noticed this problem since version 3. I will write to support and see if I get any help. Windows 10 Intel Core i5-6600K CPU @ 3.50GHz 16.0 GB RAM Geoff DeMuth |
I am using version 4.6.2 and I have the same problem. Automation on all kinds of VSTi's doesn't work when exporting the project to one audio file. It seems to be random: some track automation works but every time some automation is not read during the exporting.
This problem should be a priority for Presonus, as it impacts the workflow and the whole end result of the user experience of the DAW. I haven't found a workaround on this, and bouncing every individual track and checking that the automation was bounced correctly is really time consuming and frustrating. I'm really considering changing to another DAW because of this. |
Same problem here, using version Studio 5.1.2.
It mostly happens to 1 or 2 automation out of 200+ tracks, but everytime I bounce the faulty automation channels, the problem just begins with another channel suddenly. I've been trying to bounce 1 track now for more than 1,5 hours, on a deadline for a big client, and have to explain them my DAW is glitching, which it utterly unprofessional. Everytime you think Studio One fixed something, another big problem comes up... |
This bug is very old, shame it's still not fixed.
The only solution I found is to grab the export window every 1 minute (before it freezes) i just slightly move it. That keeps the rendering in the foreground and automation is rendered properly.
OS: Windows 10 Pro x64 DAW: Studio One Professional x64 Gear: RME Fireface 802 + RME Advanced Remote, Prometheus Acoustics monitors, Avantone Mixcubes, JBL 305p, Softube Console 1, Presonus Faderport, AKAI Advance 61, Presonus Faderport, Beyerdynamic DT-990 Pro |
wdkbeats wroteThis bug is very old, shame it's still not fixed. Boi that’s something I didn’t try yet, gonna try it tomorrow first hand, will keep you posted if it works for me! |
rubennorg2 wroteBoi that’s something I didn’t try yet, gonna try it tomorrow first hand, will keep you posted if it works for me! Cool, let me know if it works for you
Grabbing the window does seem to work for non-real-time mode, thought i haven't tried it in real time yet with my outboard gear.
At least there is a workaround so far. |
Wow. This problem has been frustrating me since version 3. Finally found this work around. What a relieve. Rather strange though that Presonus must know about this bug and somehow decided that it doesn't have enough priority to fix it for several years. It probably only affects a small minority of the users, but still..... I am going to send in another bug report. Hopefully this helps. Anyway, glad there is a work around.
W10 64 bit Designare z390 motherboard Intel I9 9900K Apollo 6X Thunderbolt Studio One 5.2.1 Professional |
formula428 wroteGrabbing the window does seem to work for non-real-time mode, thought i haven't tried it in real time yet with my outboard gear. Also known among Studio One users as "Shaking the Box". PreSonus haven't yet figured out what causes this bug even though it has been around for 5+ years. |
I've written a script that does the moving of the window automatically Works really well for me.
If you have the free program Auto Hotkey installed, save the code below via Notepad and add the .ahk extension. If you double click this file before rendering it will run in the background and move the progress bar window every ten seconds. If you use Studio One in a language other than English, you will need to change the name of the window in the script. CoordMode, Mouse, Screen Z:=0 Loop { Sleep, 10000 WinWait, Please wait... ahk_exe Studio One.exe WinGetPos, X, Y,,, Please wait... X:=X+100 ; coordinates for empty spot in window title bar Y:=Y+15 Click, %X% %Y% 0 ;move to coordinates but don't click Click, Down If Z = 0 { X:=X+5 Y:=Y+5 Z:=1 } else { X:=X-5 Y:=Y-5 Z:=0 } Click, %X% %Y% 0 Click, Up } |
ezraboucher wroteI was having this problem + got it to work by rendering the mixdown in real time. Glad this worked for you. I usually render in real time and more often than not I do experience the bug in that scenario. In my experience the CPU load plays a role. The bigger the load the bigger the chance of the bug occuring. Real time rendering lowers the CPU demand in most cases so it may help, but it isn't a real solution, or at least not for me. |
Users browsing this forum: No registered users and 112 guests
