Mackie/Icon/X-Touch users - Pageable mapping available (+ Fader support)
Posted: Fri Aug 07, 2020 11:21 am
Download from here:-
http://getpatched.co.uk/forumattachment ... _LSMod.zip
EDIT:- Latest version http://getpatched.co.uk/forumattachment ... Mod_v3.zip
And copy the 'Mackie_LSMod' folder into:-
Win
C:\Users\YOURNAME\AppData\Roaming\PreSonus\Studio One 5\User Devices
or
C:\Users\YOURNAME\AppData\Roaming\PreSonus\Studio One 4\User Devices
Not sure where they go on mac, it's in application support folders i think.
You then just remove your ports from the existing MIDI setup you have and find Mackie LSMod in the list and assign your ports to that. You can always return back to the default if you do it this way.
With this mapping, it will utilise the paging system added to S1 for Faderports (Around v4.5 i believe?) and displays it on the included skin. I've tweaked a few other elements to suit my workflow, here's a list of changes:-
Channel Left/Right
Change parameter page - (Use control link to map as per usual in 'plugin' mode)
Shift+Channel Left/Right or Option+Channel Left/Right
Toggles through tabs on windows - such as insert slots.
Using that combo allows you to quickly change pages and plugins for the focused track.
Shift+Bank Left/Right
Now acts as the old channel left/right button (i.e. steps one track at a time).
Option+Bank Left/Right
Scrolls through presets for the focused plugin (This is standard mapping).
Shift+Plugin button
Opens/closes inserts for the track.
Shift+Instrument
Opens/closes VST Instrument for the track. (Standard mapping)
With Scrub Held
Jog Wheel - quickly moves between tracks (i.e. cursor up/down) - this also allows you to browse plugin inserts quickly.*
Left/Right buttons - Moves existing loop range up or down the timeline.
Down button - Sets loop start
Up Button - Sets loop end
*Example of adding an insert to a track using the jog wheel:-
Press F5 on the Mackie (Add insert function)
Hold Scrub and turn the Jog wheel to browse the list
Press Enter key on MCU to load the insert
This is an early mapping, but i thought i'd share it now if anyone was wanting more parameter assignments for MCU based devices - Pages go up to 8 so that's 64 assignments per plugin available all with screen feedback.
I could also map the V pot select/presses (Rather than them being 'reset to default' buttons). But not sure if i can get that showing on the hardware display, can definitely get it on the remote skin though.
Any feedback or ideas would be cool, i'm going to pre-map all the presonus plugins if i get time.
Win
or
Channel Left/Right
Shift+Plugin button
Shift+Instrument
With Scrub Held
