Download from here:-
http://getpatched.co.uk/forumattachment ... _LSMod.zip
EDIT:- Latest version http://getpatched.co.uk/forumattachment ... Mod_v3.zip
And copy the 'Mackie_LSMod' folder into:-
Win
C:\Users\YOURNAME\AppData\Roaming\PreSonus\Studio One 5\User Devices
or
C:\Users\YOURNAME\AppData\Roaming\PreSonus\Studio One 4\User Devices
Not sure where they go on mac, it's in application support folders i think.
You then just remove your ports from the existing MIDI setup you have and find Mackie LSMod in the list and assign your ports to that. You can always return back to the default if you do it this way.
With this mapping, it will utilise the paging system added to S1 for Faderports (Around v4.5 i believe?) and displays it on the included skin. I've tweaked a few other elements to suit my workflow, here's a list of changes:-
Channel Left/Right
Change parameter page - (Use control link to map as per usual in 'plugin' mode)
Shift+Channel Left/Right or Option+Channel Left/Right
Toggles through tabs on windows - such as insert slots.
Using that combo allows you to quickly change pages and plugins for the focused track.
Shift+Bank Left/Right
Now acts as the old channel left/right button (i.e. steps one track at a time).
Option+Bank Left/Right
Scrolls through presets for the focused plugin (This is standard mapping).
Shift+Plugin button
Opens/closes inserts for the track.
Shift+Instrument
Opens/closes VST Instrument for the track. (Standard mapping)
With Scrub Held
Jog Wheel - quickly moves between tracks (i.e. cursor up/down) - this also allows you to browse plugin inserts quickly.*
Left/Right buttons - Moves existing loop range up or down the timeline.
Down button - Sets loop start
Up Button - Sets loop end
*Example of adding an insert to a track using the jog wheel:-
Press F5 on the Mackie (Add insert function)
Hold Scrub and turn the Jog wheel to browse the list
Press Enter key on MCU to load the insert
This is an early mapping, but i thought i'd share it now if anyone was wanting more parameter assignments for MCU based devices - Pages go up to 8 so that's 64 assignments per plugin available all with screen feedback.
I could also map the V pot select/presses (Rather than them being 'reset to default' buttons). But not sure if i can get that showing on the hardware display, can definitely get it on the remote skin though.
Any feedback or ideas would be cool, i'm going to pre-map all the presonus plugins if i get time.
Win10 Desktop - I7-4790/IGU/SSD (Main audio machine) | Win10 Laptop - i7-950H/GTX1660Ti/SSD | 12 Core 2012 Xeon Mac Pro | 2008 Mac Pro | 2012 Macbook Pro | 2015 iMac | Focusrite Liquid Saffire 56 + ADATs | PreSonus Sphere | Waves | Arturia V Collection | Komplete Suite | Mackie MCU | Yamaha MOXF8 | Roland FA06, System-1, TD-1KV | Korg Microkorg | Komplete S61 Mk2 | Maschine Mk2 | Nektar P6
by auricle on Sat Aug 08, 2020 3:00 am
Thanks for this! I've sent you a PM with my suggestions.
Just for reference, Mac users will need to place the folder here:
/Users/*username*/Library/Application Support/PreSonus/Studio one 5/User Devices/
/Users/*username*/Library/Application Support/PreSonus Software/Studio one 4/User Devices/
by leonseaman on Sat Aug 08, 2020 3:47 pm
Ok, i've updated this mapping so that VSelects (Press down on the V pots knobs) can be mapped, and are also pageable.
http://getpatched.co.uk/forumattachment ... Mod_v2.zip
Again, copy Mackie_LSMod folder into:-
Win
C:\Users\*username*\AppData\Roaming\PreSonus\Studio One 5\User Devices
or
C:\Users\*username*\AppData\Roaming\PreSonus\Studio One 4\User Devices
Mac (As supplied above)
or
There's also an additional "Mackie LSMod Control.surfacedata" file included, these are converted factory mappings from the faderport 8, and should automatically copy across first time you create the control surface in Studio One.
Which, obviously will provide pre-mapped stock plugins.
New controls:-
The 'NAME/VALUE' button on the controller can be used to show VSelect mappings on the device and OSD. Pressing it will:
Change
[Line 1] VPot Parameter
[Line 2] VPot Value.
to
[Line 2] VSelect Parameter.
I can alternatively get the second option to display:-
[Line 1] VSelect Parameter
[Line 2] VSelect Value.
Not sure what i prefer yet, need to map some EQ's to find out as they will work with the vpot selects most.
by leonseaman on Sat Aug 08, 2020 4:33 pm
Tried to get it onto PreSonus exchange too, but it seems you need a signature file to be generated - asking support how to obtain that.
by leonseaman on Sun Aug 09, 2020 9:04 am
Third update:-
1. Added ability to map to motorised faders
2. Made faders pageable too!
3. Adde "P", "S" and "F" labels to Remote skin (P=Vpots, S=VPot selects, F=Fader), so you can see what's mapped to each - not all plugins have very distinctive label names though.
Flip Mode now:-
Flips between Vpots and Fader mappings - Display on device will update to reflect vpots state.
Name button now:-
Mode 1 - displays Vpots label + Vpots value
Mode 2 - displays Vpots label + Fader label
I figured that having the Vpot and Fader displays were more crucial than the Vpot presses.
Note: I messed the skin up for hidpi displays, it's low quality - but i will fix this later.
Mapping EQ plugins is great with the added fader controls, as you can have gain on the faders and frequency on the vpots.
Very pleased with this, and makes any MCU powered device extremely flexible with S1 now! 128 Parameters can be mapped per plugin via the Faders and Knobs, with another 64 on top of that via the press button rotaries.
Have fun :)
by PtSkillz on Thu Oct 01, 2020 9:36 am
Im stuck after i moive the folder to the right spot. wher edo i chane the midi setting in the program?
by jameservin1 on Thu Oct 22, 2020 1:26 pm
Hey this is amazing!!!
Have you tried it with the Studio One 5.1 update. For some reason I am getting an error when I press the send button!
Any helpw ould huge!
Thanks
by zoltnbn on Sun Mar 21, 2021 2:56 pm
jameservin1
In MackieControl.js file in the LS_mod folder find line:
return mixerConsole.audioMixer.getMaxSlotCount (FolderID.kSendsFolder);
and change it to:
return mixerConsole.audioMixer.getMaxSlotCount (PreSonus.FolderID.kSendsFolder);
Send issue gone
by brianewell on Sat Sep 25, 2021 1:22 pm
Thank you so much for doing this! This solves a problem I have been fighting for two years with my SSL Nucleus and Studio One. I'd still love if they allowed a grouped device to act as a single unit but this solution you provided has made things way better than they were before. It is much appreciated.
by pawelhebda on Sun Sep 26, 2021 11:20 am
Great work!!! Thank You
Users browsing this forum: nikolaospitloglou and 36 guests
