So I've been researching this for a while and have noticed the issue for a while as well but to workaround the problem for sake of saving time troubleshooting I have been editing my MIDI notes to lengthen them giving me the desired result of a Sustain.
But now taking more time to look into the problem it appears that this is an issue that has plagued Studio One as far back as 2016 from what I can determine. I've gone through every resource I can find and nothing I've done seems to resolve the issue that SO5 simply won't acknowledge Sustain Pedal events. I've de-selected all the filter options within the Device settings within SO5 and also manually added the pedal sustain MIDI event (though I can't for the life of me understand why I'd have to do this manually when every other DAW I've ever worked with simply acknowledges such a basic required function) Still no resolve. I can bring up any stand alone VST outside of SO5 or use another DAW and there is no issue with the Sustain event; which tells me this issue has nothing to do with my hardware or system configuration. I am a bit disappointed after having recommended SO to so many others and raving about it that such a trivial requirement has such an extended history of the DAW and is still an obvious bug; or a basic expected feature that requires manual setup. Okay..... done venting. So what's the magic fix that I'm overlooking? Thanks |
I know it’s probably no comfort but my sustain pedal data is handled just fine and my specs/platform are similar to yours. Can you give more data of how exactly everything is setup or show a video of how the issue is occurring? Things that I’m wondering:
- what sustain pedal are you using and how is your sustain pedal connected to your computer? - Does a sustain pedal function via any other hardware? You can easily test this with the QWERTY Keyboard device in Studio One- I think the Tab key is mapped to sustain in that situation. - Can you write CC64 with a knob on any other control surface and test it that way? It may sound silly but one time I accidentally assigned CC64 to a global parameter with Control Link and it would intercept it before it reached the instrument... Side note, I’m pretty sure the “since 2016” issue you mentioned was one where sustain pedal data would not record properly on Loop 2+ when loop recording on an Empty Instrument Track. Are you using an Empty Instrument Track? |
robertgray3 wroteI know it’s probably no comfort but my sustain pedal data is handled just fine and my specs/platform are similar to yours. Can you give more data of how exactly everything is setup or show a video of how the issue is occurring? Ugh... correct, no comfort But yes, I can definitely provide more info robertgray3 wrote- what sustain pedal are you using and how is your sustain pedal connected to your computer? Just a regular ProLine Foot pedal connected directly to my Yamaha XF8 keyboard which is connected to the iMac via a USB port robertgray3 wrote- Does a sustain pedal function via any other hardware? You can easily test this with the QWERTY Keyboard device in Studio One- I think the Tab key is mapped to sustain in that situation. The sustain pedal functions as expected outside of Studio One with every other application I have. I can affirm that the QWERTY keyboard sustains the note just fine using the tab key although I would think that only affirms that a software keyboard controller works. robertgray3 wrote- Can you write CC64 with a knob on any other control surface and test it that way? It may sound silly but one time I accidentally assigned CC64 to a global parameter with Control Link and it would intercept it before it reached the instrument... Unfortunately I can't as I use the XF8 as my only controller interface and it is only for triggering MIDI keys, sustain, pitch bend and modulation info. I don't really have any need of additional controller interfaces. Aside from it, I only use Console1 on occasion as a Channel strip. I'm providing a screenshot of the MIDI setup for the XF8 within SO5 and have also recording a short video showing the issue. You will note in the video that SO5 is actually receiving the Sustain MIDI event during the record; it simply doesn't record it. Even after manually adding the event to the editor there is no info showing. I recorded a pitch bend near the end just to show that both types of events are being recognized but SO5 is only recording the pitch bend. The MIDI event indicator on the transport and the External device window (also included in the vid) both affirm the sustain pedal event is being acknowledged but neither during the play or record is SO5 sustaining the event. SO5 External MIDI Setup SO5 Not recording pedal sustain events Hopefully its a simple fix that I'm missing but I can't identify any SO5 setting to resolve the problem and I'd accept it as a hardware or software related issue with my Keyboard or drivers only if it were not for the fact that I have no issue with this in Cubase or any standalone of the identical VST instruments. Only in SO5 Thanks for helping out. |
robertgray3 wrote.....This happens with all plugins right, not just a few? This "happened" across all plugins that would support sustaining notes. Notice the past tense here I don't rule any advice out as being silly so I did delete the User Device, closed SO5 and created a new one per your suggestion and I'm glad to report the issue is resolved. Though it doesn't give me a very confident feeling that it even occurred because I don't abuse the DAW in any way and having random issues crop up can be very frustrating. Especially those types that have no logical explanation except that they just "happen" Thanks again! I can now resume my work having the functionality I expected |
j0001s wroteHave you opened up the Studio One MIDI monitor and see if Studio One thinks that it's received it? I'm not near my DAW right now, but IIRC, you click on the MIDI icon at the bottom of the screen to open it. Thanks for the suggestion j0001s! Yeah, I did confirm that SO received the MIDI message |
Occasionally going from a major version to a major version there can be odd behaviour with external devices but once you do delete and make a new one there will rarely be any issues from that point on.
Does your sustain pedal have a polarity reverse switch?
Note that some keyboards (including Yamaha) reverse close to sustain/open to sustain pedal response depending on if the pedal is plugged in before or after the keyboard is powered up. If your pedal has a polarity reverse switch then try using it reversed (and reverse your plug-in/power up routine too). See if that makes S1 register the pedal input |
mivey wroteThanks again! I can now resume my work having the functionality I expected No problem. Corrupted external device maps (at least I think that’s what they are) are an annoying issue but luckily they’re pretty rare, the fix is easy, and as Jemusic mentioned it usually only happens when upgrading to a major version. At least that’s the only time I’ve seen it happening outside of when I’m building custom devices, but during that process I’m constantly changing the Device maps anyway. |
robertgray3 wroteAlso this might sound silly but have you tried deleting the User Device, closing Studio One, and making a new one? If you’ve mapped a lot of stuff you should back it up first. Can you explain what the User Device would be? Do you mean the keyboard which the pedal is connected to?
Presonus Featured Artist (Italy)
My Latest Feature Requests https://answers.presonus.com/73692/s1-essential-feature-plugin-racks https://answers.presonus.com/72506/zoom-to-selection-improvement-vote-if-you-agree Studio One Pro 6 Win10 - AMD Ryzen 9 5900X - 32gb ram DDR4 Gigabyte RTX 3060 Interface: Focusrite 18i20 3rd gen Prophet XL + KeyStep Pro Atom SQ Revelator |
robertbaker20 wroteAny update to this? Seems like such a silly thing not to work. I have 2 sustain pedals...they both work fine, except for with Studio One. All my pedals work fine with Studio One. I can't reproduce this issue. Can you provide more information? What exactly is the result in the piano roll editor when you record notes with Sustain Pedal (CC64) messages? Did you submit a support ticket?
Lukas Ruschitzka
Users browsing this forum: Hommi and 99 guests
