I Issued a support ticket but was referred to ask on this forum, I'm using an Elgato Stream Deck for keyboard shortcuts and have been for the last year or so, it has randomly stopped working in my studio one 4.6.2.58729
Now the Elgato Stream deck works fine with other programs and notepad, my main use is for studio one.
I have also done the usual, uninstalled Elgato Stream deck software, reinstalled, changed USB ports and tested two other hubs, it only seems to be studio one affected by this.
Quick Example, I have shortcuts set for bounce, quantize, duplicate, split at grid, transpose... etc None of them work... in studio one but if I open note pad I can see them being typed out.
Can you suggest anything in studio one to check? anyone else have the same issue?
just a side note... I'm not ready to transfer over to V5 just yet and would like to keep using V4 for the next few months (I have a few projects I need to finish in V4). The Elgato Stream Deck is massively part of my workflow as I don't have to remember any shortcuts.
Thank you in advance for any help.
Many Thanks
TJ
by nonchai on Sun Nov 08, 2020 12:54 pm
same issue here with 5.1
by nonchai on Sun Nov 08, 2020 12:57 pm
Using the StreamDeck XL on iMac 2018. Catalina
by nonchai on Mon Nov 09, 2020 3:06 pm
nonchai wrotesame issue here with 5.1
StreamDeckS1BUG.zip
(1.26 MiB) Downloaded 168 times
by nonchai on Mon Nov 09, 2020 3:07 pm
nonchai wrote[attachment=0]StudioOne 2.png[/attachment
by jazzundso on Mon Nov 09, 2020 6:09 pm
Did you report that to the support?
Lukas Ruschitzka
Studio One Specialist
Studio One Tutorials || Studio One Scripts & Add-ons || Studio One Tutorial Database || Studio One Toolbox [ s1toolbox.com ]
Clavia Nord Stage 3 - Moog Sub 37 - YAMAHA MoXF6 - M-Audio Axiom Pro 61 - Kawai ES-920 - Studio One 5 - Notion 6 - Orchestral Tools Junkie XL Horns, ProjectSAM Symphobia, Cinematic Studio Series, Strezov Sampling Afflatus, VSL Synchron Special Edition, KOMPLETE 9 Ultimate
by newlinkeen on Fri Nov 26, 2021 12:19 pm
Stream Deck suggests not using a USB hub but, rather, plugging directly into your computer. You might be OK if your hub is a powered hub. Strange it work fine with some apps and not others but the hub may be contributing to the issue. Not an expert but a thought.
by lousyracuse on Fri Jan 28, 2022 12:44 am
newlinkeen wroteStream Deck suggests not using a USB hub but, rather, plugging directly into your computer. You might be OK if your hub is a powered hub. Strange it work fine with some apps and not others but the hub may be contributing to the issue. Not an expert but a thought.
I have had similar issues with other USB devices that have lights or displays. That power has to come from somewhere, so if you are connecting to a USB hub I highly recommend using a powered hub. YMMV
I'm somewhat surprised the StreamDeck XL is able to run off USB power with all those button displays. There are fewer (non-color) displays on my Faderport8, and it requires an AC adapter. In its defense, it does have over 50 lightable buttons. LOL
Users browsing this forum: No registered users and 50 guests
